My new NAS components.
ArgaWoW
<div class="bbWrapper">I am planning to build a new NAS with the following components:<br /> <br /> Asus Z10-pe d16 motherboard<br /> 2pcs. e5-2683 v3 processors<br /> 32 gb ddr4 ecc ram Samsung 2133mh<br /> Psu 1000w 80bronze<br /> 6pcs. Wd-red 8tb in a raidz2<br /> Samsung SSD 500gb for jails and vm <br /> <br /> I want to do backup, using it as netstorrage and run plex with the possibility to do 4k playback.<br /> <br /> <br /> What do you guys think about my setup?<br /> <br /> Thanks for any respons :)<br /> <br /> Gesendet von meinem SM-G955F mit Tapatalk</div>
joeschmuck
Old Man
<div class="bbWrapper">Moved thread to appropriate section.<br /> <br /> How are you splitting up the RAM between the CPUs? 16GB per CPU?<br /> <br /> If you did not mention using this for VMs, I'd say it was a bit overkill. With that said, I feel the CPU to RAM ratio is not proper. If you plan to run VMs then you may need more RAM. Lord knows you will have more than enough CPU cores. My advice, start with a single CPU. If you find you really need more, buy the second one.<br /> <br /> Here is the downside... Any single threaded application will only use a single core and with a passmark of 1654 per core, that is not very fast. You should not assume everything will be treated as multi-threaded. Plus the cost of your CPU is very high, unless someone gave you the CPUs.<br /> <br /> You should visit the Plex Forum to figure out what is required to stream 4K videos.</div>
ArgaWoW
<div class="bbWrapper">Hello, I have got this cpu and don't have to pay for it. So this will be ok. Primarily I plan to use it for plex and this will be ok. I will start with 16gb ram per cpu and will increase it later. <br /> <br /> Perhaps a stupid question. Will it be possible to run one processor without HT?<br /> <br /> Gesendet von meinem SM-G955F mit Tapatalk</div>
joeschmuck
Old Man
<div class="bbWrapper"><blockquote data-attributes="member: 51095" data-quote="ArgaWoW" data-source="post: 385152" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385152" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385152">ArgaWoW said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Will it be possible to run one processor without HT? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>That is a tricky question that only the BIOS can answer. Go into the BIOS and see what options you have. I'm not use to multi-cpu machines so I can't tell you if you can select each CPU seperately but you should be able to turn off all HT at a minimum. With your core count, I don't see that as a problem.</div>
ArgaWoW
<div class="bbWrapper"><blockquote data-attributes="member: 101" data-quote="joeschmuck" data-source="post: 385155" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385155" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385155">joeschmuck said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> That is a tricky question that only the BIOS can answer. Go into the BIOS and see what options you have. I'm not use to multi-cpu machines so I can't tell you if you can select each CPU seperately but you should be able to turn off all HT at a minimum. With your core count, I don't see that as a problem. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Tricky is better than stupid :) <br /> <br /> I don't have the board yet. It is just ordered an will arrive next week. I will see what options I have in bios. I guess it will be fast enough in any case.</div>
Stux
<div class="bbWrapper">Fairly certain, HT on or HT off. there is no half HT.</div>
BigDave
FreeNAS Enthusiast
<div class="bbWrapper">Are you sure that BSD is supported (by this board)?</div>
ArgaWoW
<div class="bbWrapper"><blockquote data-attributes="member: 33412" data-quote="BigDave" data-source="post: 385278" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385278" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385278">BigDave said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Are you sure that BSD is supported (by this board)? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Now I am scared:/.... i hope it will work with freenas 11[emoji22] <br /> <br /> Gesendet von meinem SM-G955F mit Tapatalk</div>
joeschmuck
Old Man
<div class="bbWrapper"><blockquote data-attributes="member: 33412" data-quote="BigDave" data-source="post: 385278" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385278" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385278">BigDave said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Are you sure that BSD is supported (by this board)? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>What makes you say that? It's an Intel chipset, even the NIC. I didn't see any warning signs when I took a quick look at the board.</div>
BigDave
FreeNAS Enthusiast
<div class="bbWrapper"><blockquote data-attributes="member: 101" data-quote="joeschmuck" data-source="post: 385299" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385299" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385299">joeschmuck said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> What makes you say that? It's an Intel chipset, even the NIC. I didn't see any warning signs when I took a quick look at the board. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote> <script class="js-extraPhrases" type="application/json"> { "lightbox_close": "Close", "lightbox_next": "Next", "lightbox_previous": "Previous", "lightbox_error": "The requested content cannot be loaded. Please try again later.", "lightbox_start_slideshow": "Start slideshow", "lightbox_stop_slideshow": "Stop slideshow", "lightbox_full_screen": "Full screen", "lightbox_thumbnails": "Thumbnails", "lightbox_download": "Download", "lightbox_share": "Share", "lightbox_zoom": "Zoom", "lightbox_new_window": "New window", "lightbox_toggle_sidebar": "Toggle sidebar" } </script> <a href="https://www.truenas.com/community/attachments/supportos-jpg.18851/" target="_blank" class="js-lbImage"><img src="https://www.truenas.com/community/data/attachments/18/18438-b1e4e634de553ba35ba7c12da40efa36.jpg" class="bbImage " style="" alt="supportOS.JPG" title="supportOS.JPG" width="150" height="97" loading="lazy" /></a></div>
joeschmuck
Old Man
<div class="bbWrapper">I suspect that Asus just didn't try any flavor of BSD on the platform, not that it was tested and failed. I think BSD is not as common as Linux and Windoze.</div>
BigDave
FreeNAS Enthusiast
<div class="bbWrapper"><blockquote data-attributes="member: 101" data-quote="joeschmuck" data-source="post: 385304" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385304" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385304">joeschmuck said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I suspect that Asus just didn't try any flavor of BSD on the platform, not that it was tested and failed. I think BSD is not as common as Linux and Windoze. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I'm not saying it will not be compatible, I was just pointing out the lack of published support listing...<br /> I'm hoping it works for the OP without issue :)</div>
joeschmuck
Old Man
<div class="bbWrapper"><blockquote data-attributes="member: 33412" data-quote="BigDave" data-source="post: 385305" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385305" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385305">BigDave said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I'm not saying it will not be compatible, I was just pointing out the lack of published support listing...<br /> I'm hoping it works for the OP without issue :) </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I understand. And I hope it works without issue as well.<br /> <br /> I think it's time to order Chinese Food! :D</div>
BigDave
FreeNAS Enthusiast
<div class="bbWrapper"><blockquote data-attributes="member: 101" data-quote="joeschmuck" data-source="post: 385309" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385309" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385309">joeschmuck said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I think it's time to order Chinese Food! :D </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Sweet &amp; Sour Pork is my Fav</div>
ArgaWoW
<div class="bbWrapper"><blockquote data-attributes="member: 101" data-quote="joeschmuck" data-source="post: 385309" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385309" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385309">joeschmuck said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I understand. And I hope it works without issue as well.<br /> <br /> I think it's time to order Chinese Food! :D </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Ok, I have cancelled the order for the Asus z10. I am to scared about the incompatibility with freenas. Also I have read about this in an other treat. Can someone give me an advice for a board to buy. That's what I want to have:<br /> <br /> Sockel 1151 or 2011<br /> If possible with ddr3 ram support.<br /> Kmv-modul or HDMI connection.<br /> At least 64 gb ram support<br /> Support for a cpu with Passmark &gt; 10000 because it will be used as plex Media server. <br /> <br /> Actuall I have a Asus p9d-m with an Xeon 1220 v3. This board supports only 32 gb of ram and because i want to use some vm's<br /> <br /> I searched the internet twice, but I am not able to find what I'm looking for.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 51095" data-quote="ArgaWoW" data-source="post: 385420" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385420" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385420">ArgaWoW said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Ok, I have cancelled the order for the Asus z10. I am to scared about the incompatibility with freenas. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>That was probably unnecessary; the odds are quite good it would have worked fine. That said, though, it isn't a board we have much (or any, really, AFAIK) experience with.<br /> <blockquote data-attributes="member: 51095" data-quote="ArgaWoW" data-source="post: 385420" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385420" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385420">ArgaWoW said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Can someone give me an advice for a board to buy. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Socket 1150 boards can support 64 GB of RAM, but Socket 1151 can't. And Socket 1150 boards require DDR4, not DDR3. That means you're looking at a Socket 2011 board.<br /> The <a href="https://www.supermicro.com/products/motherboard/Xeon/C600/X9SRi-F.cfm" target="_blank" class="link link--external" rel="nofollow ugc noopener">SuperMicro X9SRI-F</a> with an Xeon E5-1650 meets your stated requirements. Up to 512 GB of RAM, IPMI, 10 SATA ports, and a Passmark around 12000 with that CPU. However, that board is discontinued, so you'd be looking at either used, or new, old stock. The current boards all use DDR4.</div>
Jailer
Not strong, but bad
<div class="bbWrapper"><blockquote data-attributes="member: 3713" data-quote="danb35" data-source="post: 385423" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385423" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385423">danb35 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Socket 1150 boards can support 64 GB of RAM, but Socket 1151 can't. And Socket 1150 boards require DDR4, not DDR3. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>You got that backwards. Socket 1150 support 32Gb and DDR3, socket 1151 64GB and DDR4.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 43288" data-quote="Jailer" data-source="post: 385432" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385432" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385432">Jailer said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> You got that backwards. Socket 1150 support 32Gb and DDR3, socket 1151 64GB and DDR4. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>That's what I get for going from memory. Thanks for the correction.</div>
ArgaWoW
<div class="bbWrapper"><blockquote data-attributes="member: 43288" data-quote="Jailer" data-source="post: 385432" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385432" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385432">Jailer said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> You got that backwards. Socket 1150 support 32Gb and DDR3, socket 1151 64GB and DDR4. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I am would really like to use the Asus z10 motherboard. Are you 100 sure it will work with freenas 11?</div>
<div class="bbWrapper"><blockquote data-attributes="member: 51095" data-quote="ArgaWoW" data-source="post: 385437" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/community/goto/post?id=385437" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-385437">ArgaWoW said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Are you 100 sure it will work with freenas 11? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I don't think any of us is 100% sure of that. It looks like it should, and most standard PC hardware does, but I don't know of anyone with personal experience with that board.</div>
