Arelius
 - Jul 3, 2023
Hi everyone, (I hope I'm posting this in the correct section!)
I want to reach out and ask for some guidance on this since I'm truly in/on uncharted waters here.
My end goal is to build my own NAS with TrueNAS running on it (haven't decided on CORE or SCALE, I think I end up with CORE..).
I have been and still are on Synology for the past 10-15 years, done some stuff to the models I have had/have but I don't want to pay and get a closed/restricted system again. And well, also I quit frankly enjoy doing/building myself.
I think the first step is the motherboard and the case and there is where I'm asking for your inputs so I can get onto some clear path and chose the initial components.
(In my head) I would this NAS to;
So, motherboard and case recommendations based on what I think I should go with/start at - please do correct me on anything and everything since you all know what you actually are doing/saying :D
Here is what I have gathered so far;
So I guess my real choices are:
During all the reading and so I ran into some stuff so here is some more question;
Dose anyone have any experience from this one and/or the ones mentioned in the comments? (maybe one has to be ok with getting stuff from AliExpress, I'm really not comfortable by the tough of that..)
I also ran into this post and therefore asking myself maybe anyone here have experience building something similar with some of these boards?
Or maybe I go down a easier path with mini-ITX MB and (in comparison) massive power supply and all that even though not much of it is needed in a NAS-build?
With best regards, Daniel from Sweden who is new here :)
- stay within or close to the form factors "Thin Mini-ITX" or "Mini-STX" (but can't say I see this being possible cause I really cant find any real purchasable motherboards).
 - be able to buy a 3D printed case for this.., I can see this being beneficial so I could potentially scale up a bit down the road - maybe or go for some (I don't know what else is out there) but cases stuff from SilverStone maybe (not really since there is no place to have the SSD disk in the cases).
 - have a motherboard with at least 2 SO-DIMM slots with support up to 64GB (maybe this is over kill?)
 - run TrueNAS on ofc and that beeing installed on a M.2 PCIE NVMe so the MB needs to have one those slots
 - have the main storage on SATA 2.5 SSD, 4-6 of them, I think I start with at least 4 disks with some swappable no-raid option (I hear raid is not great for SSD health?)
 - also have built in LAN port, 10Gb preferably (or can one combine several eg 2,5G ports?)
 - possibility to being able to back the entire storage up and out into some external drive using USB/TB (or some other interface which is just as fast?)
 - have a fanless build (only if possible) but this is not something I can’t compromise on and at the most I think it would ok with a low-profile CPU cooler and maybe one case fan or so but this all depends on the motherboard and the case which should be the very heart and soul of everything so to speak
- Supermicro X13SAV-PS (from what I gather reading about these boards, power consumption is high on and also I don't think I can get my hands on one from where I live.. so maybe not a actually choice to have on the list)
- ASUS H410 or N4000 (can't seem to find where these one can be bought though)
 - ASRock H470M-STX or E3C246D4I-2T (same here, can't seem to find where these one can be bought)
 - Some GIGA-BYTE variants I guess
 - MSI H510TI-S05
