Hi all,
I'm looking to build my first FreeNAS server (exciting stuff!), but after having done a lot of research over the last few days, such as reading the "FreeNAS Community Hardware Guide" and "FreeNAS Quick Hardware Guide" on this forum, and coming up with part of a build that I believe will fit my needs, I'm struggling to figure out how to fill the gaps in this build, and I'm not even sure if the parts I have selected so far are even suitable for my needs. So I was wondering if you could help me move forward.
My use case is as follows:
Regarding the CPU, the hardware guides' advice on this also seems a bit out-of-date because the ones I've checked under the sections "Light usage" and "Medium usage" also seem to be at end-of-life (but again I'd love to proven otherwise).
Regarding the PSU, I know that I shouldn't skimp on it because otherwise it may not be powerful enough to power all the other components. I've thought of using pcpartpicker to find a suitable one when I've chosen all the other components, but my research so far has shown that not all Supermicro motherboards are available to choose from there, so I won't be able to choose a PSU there reliably. I then saw that one of the hardware guides said that I can measure the power I need with the formula "(30W+TDP of other parts)*1.2", but I'm not entirely sure what TDP means in this context. Once I figure this out, I'm sure I can then choose a suitable PSU from the "FreeNAS Quick Hardware Guide".
So, here are my questions:
1) Any thoughts on which motherboard I should go for, or even better, any advice on how I can find a suitable one myself?
2) Any thoughts on which CPU would work best for this motherboard given my use case above, or even better any advice on how I can research this myself?
3) Does anyone know what "TDP" means in the context of a choosing a PSU?
4) Will this build consume 50-60 watts, or is it too hard to tell at this point?
5) Any obvious components that I'm missing, or anything that I can do to improve this build in general?
I look forward to your responses!
Best regards,
Jonathan
- Replace my existing openmediavault system, which is running on an Odroid HC2, with a system that is hopefully less likely to fail on me in the foreseeable future.
- Store a bunch of FLAC & MP3 music and other personal files (~160GB), accessible over SMB or Syncthing.
- Potentially store music belonging to my father, adding up to 15GB currently, but which may increase significantly in the future.
- Be able to stream all this music to our home SONOS system over SMB, or Plex or some other media server. Not sure if I'll need transcoding. If I use a media server, I'll probably install it as a plugin or Jail on the FreeNAS system.
- Have a daily backup process, preferably using Borgbackup and Borgmatic as that's my current solution. I understand that I can use a custom Jail for this.
- Potentially store ISOs for a separate Proxmox/XCP-ng hypervisor build that I'm considering.
- Keep the energy bill as low as reasonably possible. Other than keeping the FreeNAS machine off during the night, I understand that there exist FreeNAS builds out there that consume only 50-60 watts when running. If so, I'd love to achieve this.
- Storage drives: 3 2TB Seagate Ironwolf hard drives, as part of a RAIDZ2 setup.
- OS drive: 120GB 2.5" Crucial BX500.
- Case: Fractal Design Node 804.
- Motherboard: ?
- RAM: 16GB ECC RAM, such as Kingston 16GB PC4-17000. Might choose another kind depending on which motherboard I go for.
- CPU: ?
- PSU: ?
- UPS: CyberPower UT650EIG.
Best regards,
Jonathan
