Hey All! I'm putting together my first FreeNAS build and I'd love some feedback. To give some background, I currently have 2 Drobo's mirrored to each other that are hooked up to my iMac. I plan on moving the drives (all 3TB Western Digital Red drives) over from one drobo, copying the data over, then adding the others to the FreeNAS RAID. I would love some advice if there's a better way to do this.
Also, I also plan on installing plex. I need to be able to support two 1080p transcodes at once or (hopefully) one 4K transcode. I'm not confident the build bellow will meet those requirements. Anyway, I appreciate any and all advice.
I'm trying to keep the build less than $900, not including the drives. I'm not particularly attached to any of these parts so please recommend anything better you know of.
Thank You!
CPU - Intel 3.70 GHz Core i3-610 - https://www.amazon.com/dp/B015VPX2EO/
Motherboard - MSI C236A Workstation LGA 1151 - https://www.amazon.com/MSI-Intel-Motherboard-C236A-Workstation/dp/B01DT49X4C
RAM - Crucial 16GB Single DDR4 (PC4-2133) CL15 DR x4 ECC Registered DIMM 288-Pin Server Memory - https://www.amazon.com/dp/B00KK8XNLA/ref=psdc_172500_t3_B015YPAZPU
Boot Drive - SK Hynix Flash Memory 2.5" 120 GB SSD - https://www.amazon.com/dp/B01H5KW9W4/
Case - Rosewill Stealth ATX Mid Tower - https://www.amazon.com/dp/B00N1Q2DXM/
PSU - FSP Group Hydro G HG650 650W ATX12V - https://www.amazon.com/dp/B0198QDP26/
SAS Card - LSI SAS9211-8I 8PORT Int 6GB Sata+sas Pcie 2.0 - https://www.amazon.com/SAS9211-8I-8PORT-Int-Sata-Pcie/dp/B002RL8I7M/
SAS Cables - 3WARE Cable Multi-lane Internal Cable - https://www.amazon.com/dp/B000FBYS2U/
I already have these:
HDD - 8x Western Digital RED Drives - https://www.amazon.com/gp/product/B008JJLW4M/
Thank You!
