So it's finally a time. I want to create my home data center for storage and file sharing. I was reading about whole ECC vs non-ECC and I am still non fully convinced how non-ECC might be a problem for low usage home server like mine. Hovewer i want this machine to last for years with easy upgrade-ability so i went for a build with ECC support.
Keep in mind i want this build to be reasonably cheap and because i live in Poland some parts might not be as avaliable as for example in US. Here is my build:
motherboard: ASRock E3V5 WS <- i took this motherboard because it's cheap, has 6x SATA and easy to buy in my local shops
processor: Intel Celeron G3900 <- will it be enough? As i said it's mostly for storage and file sharing. I don't plan on streaming in any foreseeable future. Or should i go with Pentium G4560? I can always upgrade later if' i'd like to start streaming media.
RAM: KINGSTON Dell server memory DDR4 8 gb 2133 Mhz ECC
Hard drives Seagate Surveillance HDD 1 TB 5900 RPM <- I will take 2 of them. 1 TB at the start should be enought for my home usage. I will probably buy additional drives as the year goes. Will this drives be ok?
PSU: be quiet! 450W System Power 7 <- cheap and highly efficient compared to other PSU in my pricetag
Case: I will use case from my old PC i found in the attic :D
Is this build alright? Should i expect any problems?
EDIT: BOOT: 8 gb pendrive. Probably the cheapest i can find
