Hi everyone
Excuse my spelling, I am not a native speaker. I will build my first freenas build. I will use it mostly for Plex data, maybe some iSCSI VMs later on. I like to have seperate hardware for separate purposes, that is why I will not use FreeNAS for Plex or VMs. The system should be cheap and low power.
Here is my build list. Any tips or stuff I should look out for?
I like the motherboard, because it already has two nics and a total of 14 drives.
The CPU I choose because of Hardware AES and low power consumption.
- Rosewill RSV-L4500 https://www.newegg.com/Product/Product.aspx?Item=N82E16811147164
 - Supermicro x11ssl-cf https://www.newegg.com/Product/Prod...permicro_x11ssl-cf-_-2W2-0014-00023-_-Product
 - Intel G3930 https://www.newegg.com/Product/Prod...4602&cm_re=Intel_G3930-_-19-117-748-_-Product
 - 6x 4TB HDDs I already have in mirror
 - BeQuiet 500w PSU I already have
 - Cheapest ECC 32GB ram I can find
