Chris Moore
- May 2, 2015
PS. That is the same kind of board I use and it has been solid as a rock for me. It has ability to use Regisered ECC memory, which can be picked up at reasonable prices on eBay, and you can upgrade all the way to 256GB of memory, if I recall correctly. I only use 64GB and my system works great with Plex, etc.https://www.ebay.com/itm/Supermicro-X9SRL-F-E5-2609-LGA-2011/222984132591
It comes with a processor and cooler, just add RAM.
The seller is including a 4 core 2.4GHz processor and a cooler, both of which are fine to start and if you see that you need more power than the 2.4GHz unit provides, this board can use CPUs up to 10 cores (or more) but I have a 10 core model in my other system board like this that I run ESXi on, so I know it works.
The CPU I use in my NAS is like this:
https://www.ebay.com/itm/Intel-Xeon...ket-LGA2011-HEXA-Core-SERVER-CPU/332661343418
The 6 core 2.6GHz processor gives me plenty of power to transcode streams in Plex and I have had no trouble with the system.
The biggest advantage of this board and processor combo is that you can use inexpensive Registered memory. Lets look at an example:
This 16GB stick of UDIMM memory is $157:
https://www.ebay.com/itm/Single-16G...E3-xxxx-V3-Atom-C2000-based-only/191591469461
This 16GB stick of RDIMM memory is $60:
https://www.ebay.com/itm/SAMSUNG-16...red-1-35V-RDIMM-M393B2G70DB0-YK0/302110582298
The board I have pointed you to will allow you to install up to 8 of those 16GB sticks of memory... Pairs are recommended.
