Jeff Lamer
 - Nov 17, 2015
OK, I switched the SATADOM to the white port as it was in the other. When it fails I do NOT see it in my BIOS. Looks like I'm off to buy a couple of good USB sticks tomorrow. Hopefully I can send the SATADOM back and get my money Back!Is it plugged in to one of the Intel SATA ports (the white ones)? If not do so. Is it detected by the BIOS when it doesn't boot? Can you manually select from the boot menu option (F11 or F12 - can't remember which) when it doesn't boot?
If none of those options work and you haven't made a bunch of changes in the BIOS then I would look at n RMA for your DOM.
Jeff
Just picked up my three drives tonight :D ( WD Red 3TB)
