Hi all,
I'm trying to do a DIY build for a Freenas box and I've currently got the following bits:
MB - MSI MS-S0891 ATX (not the IPMI one)
CPU - Xeon E3-1220 v3
Mem - 2x Hynix 8GB PC3L-12800E DDR3-1600 UNBUFFERED ECC 2RX8 CL11 240 PIN 1.35V
The problem I have is the PC will not even POST on startup. I read another thread online which suggested you can get that problem with this mb if you have registered RAM instead of unbuffered but I've checked and mine is definitely unbuffered. It also happens to be the same RAM that the poster mentioned fixed his problem in the other thread so I don't think that's the issue.
One thing I'm aware of is that the CPU I'm using doesn't have integrated GFX. Does anyone know if that is a pre-requisite for using the onboard graphics with this mb? I'm pretty sure it's not as the mb says is has it's own GPU but I also read a thread where someone suggested it was a requirement. I could replace the CPU with a E3-1226 v3 but I don't want to waste the money if it won't help.
TIA
TIA
