- May 17, 2014
When I bought my FreeNAS Mini, it did not come with mirrored boot drives. That was always something I wanted
to do, simply to reduce future headaches.
Looking at the Mini's boot device, it is a 16GB SATA DOM, (Disk On a Module). The Mini has plenty of extra
SATA ports, so I thought I would do the same thing, SATA DOM instead of USB. Next, because of discussons
indicating that USB & DOMs don't have standard sizes, I went up one size, to 32GBs.
Reading comments about some SATA DOMs, it was a mixed bag. SuperMicro's seemed good so I went with their
32GB, (and additional power converter cable since I am not using a SuperMicro motherboard). Installation was
easy, and the FreeNAS 9.3 manual was pretty clear.
If the size of the 32GB DOM from SuperMicro is twice as large as their 16GB DOM, then it was a good thing I
went with the larger size. My existing 16GB DOM is larger than half the SuperMicro 32GB DOM.
My take away from this experience, is that I would like to see a FreeNAS advanced installation option to reduce the
boot pool by 512MBs or 1GB. That's so that we can have a better chance of adding a mirrored boot device later,
using the same rough size. In my case, it would have been just a few hundred mega-bytes difference.
Anyone else using mirrored boot drives?
Did / do you have any problems?
