Hello everyone, I have been using the MineOS server for a long time, it was installed on a hard drive which unfortunately died. Now I try to install the plugin again, but during the installation I get this error. The plugin installs but doesn't work. Please help. Thanks in advance.
Install Notes:
> posix@4.2.0 install /usr/local/games/minecraft/node_modules/posix
> node-gyp rebuild
gmake: Entering directory '/usr/local/games/minecraft/node_modules/posix/build'
CXX(target) Release/obj.target/posix/src/posix.o
In file included from ../src/posix.cc:1:
In file included from ../../nan/nan.h:53:
In file included from /root/.cache/node-gyp/10.22.1/include/node/uv.h:52:
In file included from /root/.cache/node-gyp/10.22.1/include/node/uv/errno.h:25:
In file included from /usr/include/c++/v1/errno.h:26:
/usr/include/c++/v1/__config:117:2: error: "_LIBCPP_TRIVIAL_PAIR_COPY_CTOR" is no longer supported. use _LIBCPP_DEPRECATED_ABI_DISABLE_PAIR_TRIVIAL_COPY_CTOR instead
#error "_LIBCPP_TRIVIAL_PAIR_COPY_CTOR" is no longer supported. \
1 error generated.
gmake: *** [posix.target.mk:105: Release/obj.target/posix/src/posix.o] Error 1
gmake: Leaving directory '/usr/local/games/minecraft/node_modules/posix/build'
gyp ERR! build error
gyp ERR! stack Error: `gmake` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:198:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System FreeBSD 11.3-RELEASE-p14
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/local/games/minecraft/node_modules/posix
gyp ERR! node -v v10.22.1
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! posix@4.2.0 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the posix@4.2.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-10-10T02_05_43_395Z-debug.log
mineos_enable: -> YES
Starting mineos.
Starting mineos daemon...
mineos daemon started. PID: 33549
Install Notes:
> node-gyp rebuild
1 error generated.
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
Starting mineos.
