root@minecraft-jail:/usr/local/games/minecraft # echo "CXX=c++ npm install userid" | sh
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm WARN deprecated
har-validator@5.1.3: this library is no longer supported
npm WARN deprecated
du@0.1.0: no longer maintained
npm WARN deprecated
json3@3.3.2: Please use the native JSON object instead of JSON 3
npm WARN deprecated
angular-sanitize@1.5.11: For the actively supported Angular, see
https://www.npmjs.com/package/@angular/core. AngularJS support has officially ended. For extended AngularJS support options, see
https://goo.gle/angularjs-path-forward.
npm WARN deprecated
passport.socketio@3.6.2: Please check the workaround in
https://github.com/jfromaniello/passport.socketio/issues/148
npm WARN deprecated
debug@3.2.6: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (
https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated
npm WARN deprecated
npm WARN deprecated
code@1.5.0: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated
debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (
npm WARN deprecated
npm WARN deprecated
npm WARN deprecated
uuid@3.0.1: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See
https://v8.dev/blog/math-random for details.
npm WARN deprecated
uuid@3.3.3: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See
npm WARN deprecated
npm WARN deprecated
node-uuid@1.4.8: Use uuid module instead
npm WARN deprecated
hoek@2.16.3: This version has been deprecated in accordancewith the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated
request@2.88.0: request has been deprecated, see
https://github.com/request/request/issues/3142
npm WARN deprecated
angular@1.5.11: For the actively supported Angular, see
npm WARN deprecated
angular@1.7.9: For the actively supported Angular, see
https://www.npmjs.com/package/@angular/core. AngularJS support has officially ended.For extended AngularJS support options, see
npm WARN deprecated
nodeunit@0.11.3: you are strongly encouraged to use other testing options
npm ERR! code 1
npm ERR! path /usr/local/games/minecraft/node_modules/diskusage
npm ERR! command failed
npm ERR! command sh -c node-gyp rebuild
npm ERR! gmake: Entering directory '/usr/local/games/minecraft/node_modules/diskusage/build'
npm ERR! CXX(target) Release/obj.target/diskusage/src/main.o
npm ERR! gmake: Leaving directory '/usr/local/games/minecraft/node_modules/diskusage/build'
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using
node-gyp@9.3.1
node@18.14.0 | freebsd | x64
npm ERR! gyp info find Python using Python version 3.9.16 found at "/usr/local/bin/python3.9"
npm ERR! gyp info spawn /usr/local/bin/python3.9
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/usr/local/games/minecraft/node_modules/diskusage/build/config.gypi',
npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.14.0/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.14.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.14.0/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/usr/local/games/minecraft/node_modules/diskusage',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn gmake
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! In file included from <built-in>:415:
npm ERR! <command line>:12:9: warning: '_GLIBCXX_USE_CXX11_ABI' macro redefined[-Wmacro-redefined]
npm ERR! #define _GLIBCXX_USE_CXX11_ABI 0
npm ERR! ^
npm ERR! <command line>:7:9: note: previous definition is here
npm ERR! #define _GLIBCXX_USE_CXX11_ABI 1
npm ERR! ^
npm ERR! In file included from ../src/main.cpp:3:
npm ERR! ../../nan/nan.h:2536:8: warning: 'SetAccessor' is deprecated: Do signature check in accessor [-Wdeprecated-declarations]
npm ERR! tpl->SetAccessor(
npm ERR! ^
npm ERR! /root/.cache/node-gyp/18.14.0/include/node/v8-template.h:837:3: note: 'SetAccessor' has been explicitly marked deprecated here
npm ERR! V8_DEPRECATED("Do signature check in accessor")
npm ERR! ^
npm ERR! /root/.cache/node-gyp/18.14.0/include/node/v8config.h:460:35: note: expanded from macro 'V8_DEPRECATED'
npm ERR! # define V8_DEPRECATED(message) [[deprecated(message)]]
npm ERR! ^
npm ERR! In file included from ../../nan/nan.h:2884:
npm ERR! ../../nan/nan_typedarray_contents.h:34:43: error: no member named 'GetContents' in 'v8::ArrayBuffer'
npm ERR! data = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
npm ERR! ~~~~~~~~^
npm ERR! 2 warnings and 1 error generated.
npm ERR! gmake: *** [diskusage.target.mk:112: Release/obj.target/diskusage/src/main.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `gmake` failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
npm ERR! gyp ERR! System FreeBSD 13.1-RELEASE-p7
npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd /usr/local/games/minecraft/node_modules/diskusage
npm ERR! gyp ERR! node -v v18.14.0
npm ERR! gyp ERR! node-gyp -v v9.3.1
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-06-11T23_02_00_525Z-debug-0.log
