CookieNomster
- Jul 14, 2023
Hello there, i have been having some trouble for the last 3 days, scouring the internet for a soloution to no avail.
i just had a super fresh installation of truenas Core Latest version mainly to run a minecraft server using MineOS but everytime i start the installation it fails at 95% and throws this error
I don't really understand what is going on here, please try assisting me Pros of the Truenas galaxy, and much appreciated :D
MineOS had a failure Exception: RuntimeError Message: Last 10 lines: npm ERR! command failed npm ERR! command sh -c node-gyp rebuild npm ERR! gmake: Entering directory '/usr/local/games/minecraft/node_modules/diskusage/build' npm ERR! CXX(target) Release/obj.target/diskusage/src/main.o npm ERR! gmake: Leaving directory '/usr/local/games/minecraft/node_modules/diskusage/build' npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@9.4.0 npm ERR! gyp info using node@18.16.0 | freebsd | x64 npm ERR! gyp info find Python using Python version 3.9.17 found at "/usr/local/bin/python3.9" npm ERR! gyp info spawn /usr/local/bin/python3.9 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/usr/local/games/minecraft/node_modules/diskusage/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.16.0/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.16.0', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.16.0/<(target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/usr/local/games/minecraft/node_modules/diskusage', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! gyp info spawn gmake npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] npm ERR! In file included from <built-in>:400: npm ERR! <command line>:12:9: warning: '_GLIBCXX_USE_CXX11_ABI' macro redefined [-Wmacro-redefined] npm ERR! #define _GLIBCXX_USE_CXX11_ABI 0 npm ERR! ^ npm ERR! <command line>:7:9: note: previous definition is here npm ERR! #define _GLIBCXX_USE_CXX11_ABI 1 npm ERR! ^ npm ERR! In file included from ../src/main.cpp:3: npm ERR! ../../nan/nan.h:2536:8: warning: 'SetAccessor' is deprecated: Do signature check in accessor [-Wdeprecated-declarations] npm ERR! tpl->SetAccessor( npm ERR! ^ npm ERR! /root/.cache/node-gyp/18.16.0/include/node/v8-template.h:837:3: note: 'SetAccessor' has been explicitly marked deprecated here npm ERR! V8_DEPRECATED("Do signature check in accessor") npm ERR! ^ npm ERR! /root/.cache/node-gyp/18.16.0/include/node/v8config.h:460:35: note: expanded from macro 'V8_DEPRECATED' npm ERR! # define V8_DEPRECATED(message) [[deprecated(message)]] npm ERR! ^ npm ERR! In file included from ../src/main.cpp:3: npm ERR! In file included from ../../nan/nan.h:2884: npm ERR! ../../nan/nan_typedarray_contents.h:34:43: error: no member named 'GetContents' in 'v8::ArrayBuffer' npm ERR! data = static_cast<char*>(buffer->GetContents().Data()) + byte_offset; npm ERR! ~~~~~~~~^ npm ERR! 2 warnings and 1 error generated. npm ERR! gmake: *** [diskusage.target.mk:112: Release/obj.target/diskusage/src/main.o] Error 1 npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `gmake` failed with exit code: 2 npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12) npm ERR! gyp ERR! System FreeBSD 13.1-RELEASE-p7 npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /usr/local/games/minecraft/node_modules/diskusage npm ERR! gyp ERR! node -v v18.16.0 npm ERR! gyp ERR! node-gyp -v v9.4.0 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-07-14T09_28_57_248Z-debug-0.log node:internal/modules/cjs/loader:1078 throw err; ^ Error: Cannot find module 'daemonize2' Require stack: - /usr/local/games/minecraft/service.js at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15) at Module._load (node:internal/modules/cjs/loader:920:27) at Module.require (node:internal/modules/cjs/loader:1141:19) at require (node:internal/modules/cjs/helpers:110:18) at Object.<anonymous> (/usr/local/games/minecraft/service.js:3:14) at Module._compile (node:internal/modules/cjs/loader:1254:14) at Module._extensions..js (node:internal/modules/cjs/loader:1308:10) at Module.load (node:internal/modules/cjs/loader:1117:32) at Module._load (node:internal/modules/cjs/loader:958:12) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { code: 'MODULE_NOT_FOUND', requireStack: [ '/usr/local/games/minecraft/service.js' ] } Node.js v18.16.0 /usr/local/etc/rc.d/mineos: WARNING: failed to start mineos Partial plugin destroyed
