MineOS Plugin - Installation Problems
KKhoa02
Hi Y'all,
I am having some problems installing MineOS on TrueNas Core from the plugins section and is coming up with the following error/ode
Error: Minecraft had a failure Exception: RuntimeError Message: Last 10 lines: npm ERR! command sh -c node-gyp rebuild npm ERR! gmake: Entering directory '/usr/local/games/minecraft/node_modules/diskusage/build' npm ERR! CXX(target) Release/obj.target/diskusage/src/main.o npm ERR! gmake: Leaving directory '/usr/local/games/minecraft/node_modules/diskusage/build' npm ERR! gyp info it worked if it ends with ok npm ERR! gyp info using node-gyp@9.4.0 npm ERR! gyp info using node@18.17.1 | freebsd | x64 npm ERR! gyp info find Python using Python version 3.9.18 found at "/usr/local/bin/python3.9" npm ERR! gyp info spawn /usr/local/bin/python3.9 npm ERR! gyp info spawn args [ npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py', npm ERR! gyp info spawn args 'binding.gyp', npm ERR! gyp info spawn args '-f', npm ERR! gyp info spawn args 'make', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/usr/local/games/minecraft/node_modules/diskusage/build/config.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi', npm ERR! gyp info spawn args '-I', npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.17.1/include/node/common.gypi', npm ERR! gyp info spawn args '-Dlibrary=shared_library', npm ERR! gyp info spawn args '-Dvisibility=default', npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.17.1', npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp', npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.17.1/< (target_arch)/node.lib', npm ERR! gyp info spawn args '-Dmodule_root_dir=/usr/local/games/minecraft/node_modules/diskusage', npm ERR! gyp info spawn args '-Dnode_engine=v8', npm ERR! gyp info spawn args '--depth=.', npm ERR! gyp info spawn args '--no-parallel', npm ERR! gyp info spawn args '--generator-output', npm ERR! gyp info spawn args 'build', npm ERR! gyp info spawn args '-Goutput_dir=.' npm ERR! gyp info spawn args ] npm ERR! gyp info spawn gmake npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] npm ERR! In file included from :400: npm ERR! :12:9: warning: '_GLIBCXX_USE_CXX11_ABI' macro redefined [-Wmacro-redefined] npm ERR! #define _GLIBCXX_USE_CXX11_ABI 0 npm ERR! ^ npm ERR! :7:9: note: previous definition is here npm ERR! #define _GLIBCXX_USE_CXX11_ABI 1 npm ERR! ^ npm ERR! In file included from ../src/main.cpp:3: npm ERR! ../../nan/nan.h:2536:8: warning: 'SetAccessor' is deprecated: Do signature check in accessor [-Wdeprecated-declarations] npm ERR! tpl->SetAccessor( npm ERR! ^ npm ERR! /root/.cache/node-gyp/18.17.1/include/node/v8-template.h:837:3: note: 'SetAccessor' has been explicitly marked deprecated here npm ERR! V8_DEPRECATED("Do signature check in accessor") npm ERR! ^ npm ERR! /root/.cache/node-gyp/18.17.1/include/node/v8config.h:460:35: note: expanded from macro 'V8_DEPRECATED' npm ERR! # define V8_DEPRECATED(message) [[deprecated(message)]] npm ERR! ^ npm ERR! In file included from ../src/main.cpp:3: npm ERR! In file included from ../../nan/nan.h:2884: npm ERR! ../../nan/nan_typedarray_contents.h:34:43: error: no member named 'GetContents' in 'v8::ArrayBuffer' npm ERR! data = static_cast(buffer->GetContents().Data()) + byte_offset; npm ERR! ~~~~~~~~^ npm ERR! 2 warnings and 1 error generated. npm ERR! gmake: *** [diskusage.target.mk:112: Release/obj.target/diskusage/src/main.o] Error 1 npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `gmake` failed with exit code: 2 npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23) npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28) npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12) npm ERR! gyp ERR! System FreeBSD 13.1-RELEASE-p7 npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" npm ERR! gyp ERR! cwd /usr/local/games/minecraft/node_modules/diskusage npm ERR! gyp ERR! node -v v18.17.1 npm ERR! gyp ERR! node-gyp -v v9.4.0 npm ERR! gyp ERR! not ok npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-10-01T08_50_40_533Z-debug-0.log node:internal/modules/cjs/loader:1080 throw err; ^ Error: Cannot find module 'daemonize2' Require stack: - /usr/local/games/minecraft/service.js at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Module._load (node:internal/modules/cjs/loader:922:27) at Module.require (node:internal/modules/cjs/loader:1143:19) at require (node:internal/modules/cjs/helpers:121:18) at Object. (/usr/local/games/minecraft/service.js:3:14) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Module._load (node:internal/modules/cjs/loader:960:12) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { code: 'MODULE_NOT_FOUND', requireStack: [ '/usr/local/games/minecraft/service.js' ] } Node.js v18.17.1 /usr/local/etc/rc.d/mineos: WARNING: failed to start mineos Partial plugin destroyed
Any help is muchly appreciated, as I am utterly confused. Thanks :)
victort
Welcome to the forums!
It is unfortunate, but plugins are not a good way to go. They have never been reliable and everyone on the forums will recommend you don’t use them. And they are going away in the future according to IXSystems.
Some community members have created handy install scripts that work far better IMO if you care to look at those.
My signature has links to them, including MineOS.
