Hello all,
Ok I have MineOS installed on TrueNAS 12.0-U1.1. Installed it using the plugin and it is running in its own Jail inside iocage just like it should. I can connect to it and everything is running fine. What I can't find is how to do this.
I would like to have the server using a different data drive for it's stuff other than the IOCage. I have mounted another pool share to it but I can't see where inside the MineOS I would tell it to use that drive instead of the default area it is using which has to be in the Jail space which is a smaller SSD drive.
everything is running and my kids can connect just fine and all that so any help in how to connect another drive and point the data from Minecraft to that drive would be appreciated.
Thank you
Thank you
