Hello, I have a Windows 10 Pro vmdk and vhdx file for my old physical Windows 10 Computer. I converted it to a VM that would let me run it in QNAP and it worked without a problem. I just recently acquired a Cisco UCS C220 M4 Server and installed TrueNAS Scale on it. I want to use this server as my VM server and use the QNAP as my NAS.
I first used qemu-img to convert the vhdx to a raw file with this command "qemu-img convert -f vhdx -O raw Win10.VHDX Win10.raw". After the conversion was complete, I created a zvol data and transferred the raw file to a smb share on the TrueNAS server. I connected to the TrueNAS shell window and ran this command "sudo dd if=Win10.raw of=/dev/zvol/VM+Pool/Windows_VMs/Win10 bs=1M". When that completed, I created a virtual machine with the "Use existing disk image" setting, and also making sure that the system configs (CPU, RAM, Disk Space, etc) matched what I had for the Windows RAW File. Under "Select Existing zvol" I selected the Win10 zvol. After the VM creation completed, I started the VM and saw that it booted to the UEFI Shell. While Troubleshooting, I noticed that if I selected the "Enable Hyper-V Enlightenments", It would sometimes boot up to the Windows blue recovery screen, but not all the time. I've been working on this all day and cannot find a fix on this forum or with google searches.
When I couldn't get it to work with the vhdx conversion, I also ran through the same steps with the vmdk file, but that didn't work. The folder that has the vmdk file in it, also has a vmx file as well. My virtualization experience is limited so I don't know if the vmx file has something to do with it not working. I'm also new to TrueNAS so I don't know if I did something wrong with the migration process.
Any help would be greatly appreciated. If you need any more information from me or attach logs, let me know. Thanks.
System Information
System Information
- Motherboard make and model
- Unknown
- CPU make and model
- Two Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz with 8 Cores and 16 Threads each
- RAM quantity
- Six 8GB DDR4 - total 48GB
- Hard drives, quantity, model numbers, and RAID configuration, including boot drives
- TrueNAS OS installed on FlexFlash Controller using two ScanDisk 32GB SD Cards in a RAID 1 mirror config.
- There are 8 bays. 7 bays are in a RAIDz2 config for total 1.22 TiB usable space. These 7 bays have 300GB Toshiba AL14SEB030N HDD’s . The 8th Bay has a Samsung 500GB OCZ-AGILITY3 SSD installed.
- Hard disk controllers
- Cisco 12G SAS Modular Raid Controller
- Network cards
- Intel Ethernet Server Adapter I350-T4 - 4 Interfaces
- Intel(R) I350 1 Gbps Network Controller - 2 Interfaces
