daves_garage
- Mar 10, 2023
Greetings! I have a Storinator Q30 with thirty 14TB. I have an Optane stick for cache and logs. The system has 128GB of RAM. TrueNAS Scale. Xeon Silver 4216.
My issue is that read speeds are in excess of 1GB/sec (on a 10gbit NIC), but write speeds max out at 700MB/sec. This is true on any dataset, including a test I created with sync disabled.
In my mind, it should be able to take data as fast as you can send it if it's just going to the TrueNAS cache. Yet it seems to be constrained by the physical write speed. Since the 30 drives are broken up into 3 vdevs of 9 drives plus a spare each, 700MB/sec might be the limit for writing to 9 drives. But again, with sync off I thought it should just be writing to RAM cache until the cache gets full, which it's nowhere near.
What am I missing that I can try in order to get write speeds equal to the cache write speed?
Thanks!
Thanks!
