mjt5282
- Mar 19, 2013
Thank you.
The Dell card looks great value for the $$$ spent. For around $30-$50, I can get an improvement (speed + reliability) over the mobo-connected SATA drives. Am I correct?
4 questions here:
1. Does IronWolf NAS 8TB drive (ST8000VN004 one) is a good choice for NAS? Can't wait to order them.
2. AMD vs Intel in terms of NAS. I do realize that this is a big question and potentially it can start a "holy war" (that's NOT my intention). I went through SuperMicro mobos and Xeon CPUs. In general, that's an easy $2k price tag while AMD combo is well under $1k. I guess, my question is - do I really need to pay that extra? In other words, does AMD server more than twice worse (less reliable or smth else?) than its Intel counterpart?
3. For an AMD-based server - does X570 is a good choice? Is there anything better than that?
4. From what I already saw (keep looking tho), I have 2 mobos which are appealing to me:
- ASRock X570D4U-2L2T (https://www.asrockrack.com/general/productdetail.asp?Model=X570D4U-2L2T#Specifications)
- Asus Pro WS X570-ACE (https://www.asus.com/Commercial-Servers-Workstations/Pro-WS-X570-ACE/overview/)
Any other mobos which would be good for me?
I guess gaming/desktop mobos are not appropriate for my scenario.
My only recommendation on buying new hard drives is, make sure they are CMR and not SMR, *especially* if you are doing a raidz1/raidz2 configuration. Seagate makes fine CMR drives, as does WD (now branded as WD Red Plus, i believe).
It used to be several years ago that AMD CPUs were not as well supported by freebsd kernels, and freebsd is what TrueNas uses under the hood. My systems (built several years plus ago all use Intel Xeon CPUs/Supermicro motherboards . My feeling is that freebsd has 'caught' up with AMD support. If you buy a AMD CPU/motherboard, keep a careful eye on motherboard sleep/wait settings. I happen to be thinking of building a new server system, tempted to look at AMD now, write it up and let us know how it goes if you go AMD route. Good luck!
