starche.old
- Mar 4, 2021
Before I’ll start with the questions, let me tell you what I have, what I want, what I already understood reading the internet for a few days now and finally – the questions I need your answers on.
I have:
What I want:
After investing the 3 days already (and keep counting) I think I’m getting a better idea of what I need to do. I’ll put this short list – just to ensure I’ve got everything right and the community members are in agreement with that.
I’ve got quite a list of the questions:
Sorry for so many questions and thanks in advance for the answers.
I have:
- Hardware: Pretty old, but solid LGA1366 mobo – P6T6 WS Revolution (https://www.asus.com/Commercial-Servers-Workstations/P6T6_WS_Revolution) on Intel® X58 / ICH10R paired with i7-920 and 6GB (3*2GB) DDR3 RAM.
- Drives: SSD – Samsung 850 PRO (128GB) for system plus a single 8TB IronWolf and a bunch of 2TB and 3TB drives as storage.
- All that runs on zfs (RAID-Z) on Debian 10.x
What I want:
- I want to get a usable and reliable storage solution based on TrueNAS 12 (a long-time dream to play with FreeBSD after so many years on various Linux distros).
- Get rid of 2TB and 3TB drives and replace them with bigger, but fewer drives. Simple setup – 4 * 8TB drives in RAID-Z2.
- The storage will be filled (and filled now) with tons of photos, videos and such, so I do not want to lose all that.
- I was thinking to buy two 12-16TB drives to complement my single 8TB IronWolf. But after going through how zfs is working as well as the zfs storage calculator (for example – https://wintelguy.com/zfs-calc.pl) I decided to buy three 8TB drives. That will give RAID-Z2 and almost 16TB of storage (which should be enough for me – at least for now).
- Does my mobo and i7-920 CPU are good enough for the purpose?
- How critical is the RAM requirement? Yes, I’ve read that 8GB of RAM is absolutely a minimum. But will my 6GB do the trick for 4 drives only? If no, then the chances to get another matching set of three DDR-3 sticks are close to zero, thus I will need to build a new rig.
- I’m thinking to move the data from my computer and try to run TrueNAS on 6GB anyway – to see by myself how bad it might be. But maybe someone can tell me right off the bat – “it’s OK” or “don’t even waste your time on that”.
- What vendor is preferable these days? I’m a long-term user of Seagate drives, but TrueNAS is talking about WD. Does WD is any better than Seagate, or both vendors are on par?
- How much of a difference between NAS drives (WD Red/Red pro), enterprise (gold) and data center (UltraStar) drives in terms of reliability, speed, etc.? Does it make much sense to get Exos or UltraStar instead of IronWolf or WD Red?
- How bad is an idea to buy cheap Barracuda drives instead of IronWolf or WD Red if I'm using RAID-Z2?
- I've read quite a few articles about SATA vs SAS as an interface - https://store.hp.com/us/en/tech-takes/sas-vs-sata or https://www.diffen.com/difference/SATA_vs_Serial_Attached_SCSI, but I’m still confused.
- I do realize that the theoretical speed of SAS is double against SATA (12 vs 6Gb/s). But with sequential read from modern HDDs around 250-270MB/s (2.0-2.5 Gb/s), even SATA’s 6Gb/s won’t be a bottleneck, thus it makes no sense in SAS for at least 7200rpm HDDs (15k rpm HDDs in those days were the beasts). Am I missing something?
- Do I need a controller (like 9211-8i, 9300-8i and similar)?. What’s the benefit of using them? Can built-in southbridge chip handle 4 drives or not?
- If I need a controller, which one do I need? I’ve read here the topic (https://www.truenas.com/community/threads/sas-controller.89195/) that “Any LSI HBA, notably not a "RAID card" should be fine”. Is that correct?
- Why are a lot of advice to buy a Dell controller and reflash it with LSI firmware (like this one – https://fohdeesha.com/docs/perc/). Is it just cheaper this way or something else?
