Hello.
Hate for my first post to be about a problem but I really need help here. First of all let me say I'm on my second freenas build. The first one I built was a sort of proof of concept. Specs were i7 920 Cpu, basic motherboard with 10 onboard sata ports. 24Gb ram (6 x 4). It had 2 separate pools (6 x 1.5Tb) z2 and (3 x 1Tb) z1. It ran build 9.1.0 I think. Long story short it ran like a dream, you can read about it or skip to the next paragraph.
I got it running set the static ip, set up the pools, set up the shares and that was it. It just worked beautifully from day 1. All transfers were consistently in the 75-90mb/s range peaking at 115-120mb/s. My torrent computers download directory was set to one of the data set folders. I regularly had 20+ torrents going all downloading/seeding. Plus me and others streaming high bit rate bluray movies from it. It never missed a beat. I even randomly un plugged drives just to see what would happen. Even the z1 pool successfully re-silvered multiple times. I never lost the pools or any data. Huge file transfers always finished eventually without pauses or drop outs. It was just bulletproof, the 2-3 months I had it running, it never once crashed or became unresponsive. I didn't fiddle with any settings or anything all I did was just scrub the pools manually every 1-2 weeks and it continued on working flawlessly.
So I was sold. Freenas is great. Time to go out and make a larger scale nas and put all my drives in it. I believe in do it once do it right, so I decided to go down the route of getting proper server gear. Here's what I got. All 2nd hand except the motherboard witch I got brand new.
Xeon e3 1220v2
Supermicro X9SCM-F
Kingston KVR16E11K4/32 (32Gb 1600mhz ECC Unbuffered)
Lsi 9211-8i (ver 16 IT mode)
Drives. Currently have 14 1.5Tb Wd greens.
Here's my problem. I've set up a brand new empty pool and I can't even fill it up. I try to copy something to a (CIF) share and it will copy anywhere from a few hundred Meg to 10-20 Gig (seems completely random) then it will simply stop. Network traffic will drop to zero and the share will become unresponsive and the transfer will fail. Meanwhile the web GUI will continue to work as normal. Still responsive even the shell works smoothly, no errors in the console nothing. Teracopy just sits there doing nothing and eventually comes up with the error "the specified network name is no longer available". About 10-20 minutes pass (again totally random) then out of nowhere it starts to copy again another few hundred Meg to 10-20 Gig and so it goes on. Whenever it actually is transferring the share becomes accessible when the transfer stops the shares also drop out.
Going through all the menus there doesn't really seem to be anything you can change or adjust to try and fix this. I've tried running different versions of freenas even the old 8.x.x. I've tried different pool configurations. Always the same problem.
Now I know the hardware is 2nd hand and I have no idea how old it is or what its been through but I did check it. Installed windows and ran tests. Prime95 and memtest86. Ran crystaldiskmark on each channel of the HBA. Nothing was out of the ordinary. The disks, yes the disk are ancient (in computer years) and yes some of them have crazy high values for (C1)Load cycle count. But all drives have Zero (Reallocated sector count), Zero (Reallocated event count), Zero (Current pending sector), Zero (Offline Uncorrectable). I'm pretty sure everything hardware wise is 100% working so the problem isn't the hardware.
When ever it actually is transferring the speeds are very good around 100 mb/s. Scrub speed is also very good at around 740mb/s. Currently running the latest version 9.2.1.6. The current pool configuration is 6+6 z2 striped vdevs with 2 drives disconnected as spares. Ideally I would like to keep this setup. Could go 7+7 z3 striped or single 13 z3 vdev but decided to keep the option of expandability open. Can easily get 4 more drives and add another 6 disk vdev.
So please what do I do to make this work. I just want the basic CIF share to work properly. On the old nas I would get a 2Tb back up disk and just dump it into a share and in about 9-10 hours it was done. Now I spent the entire weekend and can barely even get 250gig transferred. Any info you guys need I'll gladly supply just tell me what commands to type where to get it.
Thanks in advance.
Xeon e3 1220v2
Supermicro X9SCM-F
Thanks in advance.
