Marc Allard
- Mar 16, 2014
I would like to know if it is possible to import existing virtual machines (debian) into a KVM guest.
I see no option to import a VM, so I decided to export the config after creating a VM, but I see no guid in the two vm tables from the db.
Is there a way to modify the guid to keep the activation of windows (there must me something or the activation would be lost with an update of scale (or a restoration from config)?
Thank you
Thank you
