pycvalade
- Oct 27, 2021
Hi guys,
I've been using TrueNAS Scale since BETA1 in a Proxmox VM + PCIe passthrough with no problems. I tried to upgrade the system from BETA2 to RC1 today and got stuck on ZFS Pools import at boot and found it's a problem coming back every few years on this forum.
Hitting Ctrl+Alt+Del reboots the system and choosing BETA2 in the boot menu brings the instance back up.
Would you guys advise that I:
1. just wait a few more weeks and try again
2. unplug my main storage pool from the VM, try booting from RC1 and if it works then reboot and manually import my pool back
3. unplug my main storage pool from the VM and fresh install + config import
Thanks!
Thanks!
