henne
- Nov 20, 2021
I have created an ACME certificate to be able to use the reporting and using SSL, as without I had mixed content using http behind a reverse proxy doing https.
But after a reboot kubernetes is not working anymore. In Apps I get a spinning wheel and this error in Running Jobs:
I cannot unset the pool or move it anymore, I guess the kubernetes file is using the old wrong certificate. How Can I fix this?
Cheers Chris
Error: Cannot connect to host 127.0.0.1:6443 ssl:default [Connect call failed ('127.0.0.1', 6443)]
Cheers Chris
