CaCTuCaTu4ECKuu
- Mar 2, 2023
I'm kinda in loss, can find any mentions about this problem.
Lets start from the problem
The story is that I had some kind of weird problem with metaslab and from time to time it got corrupted and I had to "repair" it. It looked like that:
It could work if pre-init script that set recovery kernel parameters initialize before pool import, but it doesn't so if you fail step you have to start from beginning
To solve previous problem I found solution in github issues #13963 and #13483 (this one have a solution)
I didnt notice it at the beginning or thought that is not related, but at the end I noticed that system was rebooting by itself and find some mentions that it may be because of RAM, to be honest I'm not sure - there is motherboard and ram compability and while it looks OK I'm not sure about lot of things, in short - I changed it but I guess now it's already late if thats even the case.
I dont have backup, ofcourse, as if I didnt expect it could happen so I at least need a way to mount pool somehow, so please, help.
My system is J1900 MB + 4SATA PCIE card
Pool is ZRAID2 6x2Tb drives
Currently running TrueNAS-SCALE-22.12.0 (problem occured while I was on 22.02.4)
For now I'm thinking if I can disable metaslabs altogether, then install truenas core and try import pool from there, but because there is not info about this exact problem I in desperate need for help
VERIFY3(rs_get_end((rs, rt) >= end) failed (10359540006912 >= 10359534558144) PANIC at range_tree.c:482:range_tree_remove_impl() Kernel panic - not syncing: VERIFY3(rs_get_end((rs, rt) >= end) failed (10359540006912 >= 10359534558144) CPU: 2 PID: 5553 Comm: z_wr_iss Tainted: P IE 5.15.79+truenas #1 Hardware name: xxxxx Call Trace: <TASK> dump_stack_lvl+0x46/0x5e panic+0xf3/0x2bf spl_panic+0xcc/0xe9 [spl] ? bt_grow_leaf+0xdc/0xe0 [zfs] ? zfs_btree_find_in_buf+0x59/0xb0 [zfs] ? pn_free+0x30/0x30 [zfs] ? pn_free+0x30/0x30 [zfs] ? zfs_btree_find_in_buf+0x59/0xb0 [zfs] ? pn_free+0x30/0x30 [zfs] ? zfs_btree_find_in_buf+0x59/0xb0 [zfs] range_tree_remove_impl+0x39d/0x460 [zfs] space_map_load_callback+0x22/0x90 [zfs] space_map_iterate+0x1a6/0x3f0 [zfs] ? rs_get_start+0x20/0x20 [zfs] space_map_load_length+0x61/0xe0 [zfs] metaslab_load_impl+0xc8/0x4e0 [zfs] ? gethrtime+0x1c/0x50 [zfs] ? metaslab_should_allocate+0x82/0xd0 [fsz] ? find_valid_metaslab+0x148/0x240 [zfs] ? arc_all_memory+0xa/0x20 [zfs] ? metaslab_potentially_evict+0x44/0x260 [zfs] metaslab_load+0x6a/0xd0 [zfs] metaslab_activate+0x44/0x100 [zfs] metaslab_group_alloc_normal+0x1bb/0x610 [zfs] metaslab_group_alloc+0x30/0xd0 [zfs] metaslab_alloc_dva+0x266/0x690 [zfs] metaslab_alloc+0xcc/0x210 [zfs] zio_dva_allocate+0xbe/0x380 [zfs] zio_execute+0x90/0x90 [zfs] taskq_thread+0x1ff/0x3c0 [spl] ? wake_up_q+0x90/0x90 ? zio_execute_stack_check.constprop.0+0x10/0x10 [zfs] ? taskq_thread_spawn+0x60/0x60 [spl] kthread+0x127/0x150 ? set_kthread_struct+0x50/0x50 ret_from_fork+0x22/0x30 </TASK> Kernel Offset: 0x19c00000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff) Rebooting in 10 seconds
- Shut down server
- Disconnect drives
- Start server
- Set recovery kernel parameters
- Connect drives
- Import pool
- Leave it running for few days
- Disable recovery kernel parameters
- Reboot
