majinjing3
 - Sep 2, 2021
I have found that truenas scale hang, then try to restart, but failed, finally, cut the power and restart.
But when import zpool, it panics.
Any ideas ?
zpool info:
Any ideas ?
[ 348.906643] VERIFY3(rs_get_start(rs, rt) <= start) failed (2681251880960 <= 2681207844864) [ 348.920358] PANIC at range_tree.c:484:range_tree_remove_impl() [ 348.931586] Showing stack for process 7142 [ 348.941029] CPU: 3 PID: 7142 Comm: z_wr_iss Tainted: P OE 5.10.42+truenas #1 [ 348.954795] Hardware name: ASUS System Product Name/PRIME Z590M-PLUS, BIOS 1017 07/12/2021 [ 348.968595] Call Trace: [ 348.976459] dump_stack+0x6b/0x83 [ 348.985231] spl_panic+0xd4/0xfc [spl] [ 348.994418] ? zfs_btree_find_in_buf+0x5e/0xd0 [zfs] [ 349.004823] ? zfs_btree_find_in_buf+0x5e/0xd0 [zfs] [ 349.015226] ? zfs_btree_find_in_buf+0x5e/0xd0 [zfs] [ 349.025659] range_tree_remove_impl+0x3a9/0x4a0 [zfs] [ 349.036135] space_map_load_callback+0x22/0x80 [zfs] [ 349.046566] space_map_iterate+0x20e/0x6a0 [zfs] [ 349.056512] ? rs_get_start+0x20/0x20 [zfs] [ 349.065940] space_map_load_length+0x61/0xe0 [zfs] [ 349.075971] metaslab_load_impl+0xf8/0x820 [zfs] [ 349.085789] ? avl_find+0x62/0xd0 [zavl] [ 349.094904] ? find_valid_metaslab+0x148/0x240 [zfs] [ 349.105118] ? arc_all_memory+0xa/0x10 [zfs] [ 349.114629] ? metaslab_potentially_evict+0x49/0x300 [zfs] [ 349.125294] metaslab_load+0xa7/0x1d0 [zfs] [ 349.134506] metaslab_activate+0x67/0x280 [zfs] [ 349.144011] metaslab_group_alloc_normal+0x463/0xad0 [zfs] [ 349.154398] metaslab_group_alloc+0x54/0x170 [zfs] [ 349.164054] ? spa_config_held+0x84/0xa0 [zfs] [ 349.173317] metaslab_alloc_dva+0x2e6/0x960 [zfs] [ 349.182750] metaslab_alloc+0x168/0x5b0 [zfs] [ 349.191757] zio_dva_allocate+0x240/0x5b0 [zfs] [ 349.200956] zio_execute+0xea/0x220 [zfs] [ 349.209595] taskq_thread+0x22c/0x490 [spl] [ 349.218406] ? wake_up_q+0xa0/0xa0 [ 349.226454] ? zio_execute_stack_check.constprop.0+0x10/0x10 [zfs] [ 349.237295] ? taskq_thread_spawn+0x50/0x50 [spl] [ 349.246637] kthread+0x11b/0x140 [ 349.254481] ? __kthread_bind_mask+0x60/0x60 [ 349.263404] ret_from_fork+0x1f/0x30
zpool info:
   pool: data
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
    data                                      ONLINE
      raidz1-0                                ONLINE
        ae7122fa-8794-4c98-bdf6-3b90acf4ae48  ONLINE
        ab8fd8a1-5bfe-431b-9694-c59190604e0f  ONLINE
        f354a921-9470-45c7-be29-2a90e9f6ed7a  ONLINE
