Jumbo packet size not working (MTU 9000) - missing sysctl variables
tanjix
Hi Guys!
I recently upgraded from TrueNAS 13 to TrueNAS Scale on my testing environment.
Whilst the upgrade went well and my pools are still alive, I have some issues on my 10G network.
From my VMWare ESXI hosts I cannot ping any more with a packet size of 8972 to my TrueNAS server (192.168.10.55):
[root@fra-esxi2:~] vmkping -d -s 8972 -I vmk1 192.168.10.55
PING 192.168.10.55 (192.168.10.55): 8972 data bytes
--- 192.168.10.55 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
[root@fra-esxi2:~] vmkping -d -s 8954 -I vmk1 192.168.10.55
PING 192.168.10.55 (192.168.10.55): 8954 data bytes
8962 bytes from 192.168.10.55: icmp_seq=0 ttl=64 time=0.486 ms
8962 bytes from 192.168.10.55: icmp_seq=1 ttl=64 time=0.411 ms
8962 bytes from 192.168.10.55: icmp_seq=2 ttl=64 time=0.403 ms
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.403/0.433/0.486 ms
[root@fra-esxi2:~] ^C
[root@fra-esxi2:~] vmkping -d -s 8955 -I vmk1 192.168.10.55
PING 192.168.10.55 (192.168.10.55): 8955 data bytes
[root@fra-esxi2:~]
Using a lower packet size works, up to max. 8954, 8955 and higher fails.
Vice vesa, from my TrueNAS box to my ESXI host, it's the same issue: Pings with jumbo packets up to 8954 work fine, 8955 and higher doesn't:
root@argos[~]# ping 192.168.10.57 -s 8954
PING 192.168.10.57 (192.168.10.57) 8954(8982) bytes of data.
8962 bytes from 192.168.10.57: icmp_seq=1 ttl=64 time=0.343 ms
8962 bytes from 192.168.10.57: icmp_seq=2 ttl=64 time=0.337 ms
^C
--- 192.168.10.57 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1003ms
rtt min/avg/max/mdev = 0.337/0.340/0.343/0.003 ms
root@argos[~]# ping 192.168.10.57 -s 8955
PING 192.168.10.57 (192.168.10.57) 8955(8983) bytes of data.
^C
3 packets transmitted, 0 received, 100% packet loss, time 2049ms
root@argos[~]#
Of course, MTU is set properly to 9000 everywhere.
I then tried to increase the sysctl variable "kern.ipc.maxsockbuf", however, this one seems not to work on TrueNAS scale, whilst it did on TrueNAS 12 and 13.
root@argos[~]# sysctl kern.ipc.maxsockbuf
sysctl: cannot stat /proc/sys/kern/ipc/maxsockbuf: No such file or directory
root@argos[~]#
Any help on the one or the other issue would be appreciated!
Thanks a lot and best wishes,
morganL
Captain Morgan
Administrator
Hi Guys!
[root@fra-esxi2:~]
^C
^C
root@argos[~]#
root@argos[~]#
Can you confirm you are using SCALE 22.02.3?
You've done all the work needed to submit a bug-report.. please do so and report back with the BugID.
I'm surprised no-one else has reported an issue.
tanjix
Hi @morganL!
Yup, it's TrueNAS SCALE 22.02.03
I reported two bugs then as I don't believe the one thing doesn't have to do anything with the other:
NAS-118223 and NAS-118224
Thanks and best wishes,
