JenWest1919
- Jun 5, 2017
Hello everyone!
Other than case fans, I feel like I'm missing something. Of course, I'm brand new to this so I wouldn't be surprised if there were problems with the build...
Note: Primary purpose is file storage and video editing/streaming (have so much raw video to edit it has to go somewhere)
HDD's:
https://www.newegg.com/Product/Prod...e=Seagate_IronWolf_4TB-_-22-179-005-_-Product
8 x Seagate IronWolf 4TB NAS Hard Drive 5900 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive ST4000VN008
CPU:
https://www.newegg.com/Product/Prod...19117630&cm_re=xeon_e5-_-19-117-630-_-Product
Intel Xeon E5-2630 V4 Broadwell-EP 2.2 GHz 10 x 256KB L2 Cache 25MB L3 Cache LGA 2011-3 85W BX80660E52630V4
CPU Cooler:
https://www.newegg.com/Product/Prod...08067&cm_re=cpu_cooler-_-35-608-067-_-Product
Noctua NH-U9S 92mm SSO2 U-Type Premium CPU Cooler, NF-A9 PWM Fans
MOBO:
https://www.newegg.com/Product/Prod...7557&cm_re=asrock_rack-_-13-157-557-_-Product
ASRock EPC612D8 SSI ATX Server Motherboard Socket LGA 2011 R3
RAM:
https://www.newegg.com/Product/Product.aspx?Item=9SIA98C5DB9343
Kingston ValueRAM 32GB (1 x 32GB) DDR4 2400 RAM (Server Memory) ECC Load Reduced DIMM (288-Pin) KVR24L17Q4/32I (Intel Validated)
PSU:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151160&ignorebbr=1
Seasonic Flagship PRIME TITANIUM 850 SSR-850TD Active PFC 80 PLUS Titanium 850W ATX 12V 135mm Fluid Dynamic Bearing Fan
CASE:
https://www.newegg.com/Product/Product.aspx?Item=N82E16811352031
Fractal Design Arc Midi R2 Black Window High-Airflow ATX Midtower Computer Case
SSD Boot Device:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820250078
WD Blue 250GB Internal SSD Solid State Drive - SATA 6Gb/s 2.5 Inch - WDS250G1B0A
HDD's:
CPU:
CPU Cooler:
MOBO:
RAM:
PSU:
CASE:
SSD Boot Device:
