Jails on 9.10
Neek
I've seen in the release notes that 9.10 has some weird issues with jails, that have to do with being a hybrid FreeBSD 9 and FreeBSD 10 system. However, I'm not sure what exactly I'm supposed to actually do to "nuke my jails templates".
I created a jail. From within the jail, if I look at /usr/local/etc/pkg/repos/FreeBSD.conf, it appears to be setting 'url' as:
url : "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
I run pkg update and it then fails, similar to what's seen in https://bugs.freenas.org/issues/14211.
But after reading that thread numerous times, I'm still unsure what I'm supposed to do to get the jail to be able to update its package list. I am running 3 other jails, one derived from pluginjail, and 2 from standard. They were all created back when I was on FreeNAS 9.3.
I'm not a noob, but I'm not a FreeBSD jails expert. I'd appreciate any suggestions what I need to do. Thanks.
ethereal
try this
vi /usr/local/etc/pkg/repos/FreeBSD.conf
then edit the file TO
FreeBSD: {
url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest",
mirror_type: "srv",
enabled: yes
Neek
Thanks a lot. I had tried that, but still, after doing that, when I run pkg update, I get:
root@plex:/ # pkg update
Updating FreeBSD repository catalogue...
pkg: http://pkg.FreeBSD.org/FreeBSD:10:amd64/latest/meta.txz: No address record
repository FreeBSD has no meta file, using default settings
pkg: http://pkg.FreeBSD.org/FreeBSD:10:amd64/latest/packagesite.txz: No address record
Unable to update repository FreeBSD
ethereal
ethereal
is freenas fully updated?
Neek
Thanks ethereal, not sure how, but my DNS was indeed messed up. It all appears to be working now. thanks!
ethereal
whoopee - better lucky than good
