FreeNAS 9.10 phpVirtualBox Jail Repo Issue?
MyVizDrake
Hello!
Upgraded to 9.10 weeks ago....currently on FreeNAS-9.10-STABLE-201605021851 (35c85f7)
Per the Installation Notes, I deleted all plugins and jails
created new jail (type standard)
created new jail (type Virtualbox 4.3.12)
Standard jail 'file /bin/sh' output is:
/bin/sh: ELF 64-bit LSB executable, x86-64, version 1 (FreeBSD), dynamically linked, interpreter /libexec/ld-elf.so.1, for FreeBSD 10.3, stripped​
pkg update, pkg upgrade and pkg install work as expected
The VirtualBox jail 'file /bin/sh' output is:
/bin/sh: ELF 64-bit LSB executable, x86-64, version 1 (FreeBSD), dynamically linked (uses shared libs), for FreeBSD 9.2, stripped​
and 'pkg update' fails with the following error
pkg: wrong architecture: freebsd:10:x86:64 instead of freebsd:9:x86:64​
output of /usr/local/etc/repos/FreeBSD.conf is
FreeBSD: {
url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
mirror_type: "srv",
enabled: yes
Googled a bunch and could find examples of this:
pkg: wrong architecture: freebsd:9:x86:64 instead of freebsd:10:x86:64​
But no references of what I am seeing
Bug or did I screw something up?
Thanks in advance!
Scott
X11-SSH-F
E3-1230 v5
16 GB RAM
6x 4 TB WD RED
EVGA 550 G2
Define R5
Jailer
Not strong, but bad
Don't update the virtualbox jail you will break it.
