• Attention, TrueNAS Community Members. General Help has now been set to read-only mode. To make sure you can easily find what you're looking for, we've relocated all relevant categories under their respective version. This change will simplify searching for information and minimize any confusion about where to post.
Register for the iXsystems Community to get an ad-free experience
jails not updating in FreeNAS-9.10
swbartley
I am having a problem with my current jails no longer being able to update I did a pkg upgrade. I can create new jails and they work fine but the old ones with the plugins are also malfunctioning. See the below:
Updating FreeBSD repository catalogue...
pkg: http://pkg.FreeBSD.org/freebsd:10:x86:64/latest/meta.txz: No address record
repository FreeBSD has no meta file, using default settings
pkg: http://pkg.FreeBSD.org/freebsd:10:x86:64/latest/packagesite.txz: No address record
Unable to update repository FreeBSD
FreeNAS-9.10-STABLE-201605240427 (64fcd8e)
D
dlavigne
Guest
Can you ping a website (eg google.com) from within the jail? That message looks like you have no DNS from the jail.
D
dlavigne
Guest
Not having name resolution would do it. If you're using DHCP in the jails, add 8.8.8.8 as Nameserver 1 in Network -> Global Configuration. Otherwise, and an entry for 8.8.8.8 in /etc/resolv.conf inside the jail.
