jails not updating in FreeNAS-9.10
swbartley
I am having a problem with my current jails no longer being able to update I did a pkg upgrade. I can create new jails and they work fine but the old ones with the plugins are also malfunctioning. See the below:
Updating FreeBSD repository catalogue...
pkg: http://pkg.FreeBSD.org/freebsd:10:x86:64/latest/meta.txz: No address record
repository FreeBSD has no meta file, using default settings
pkg: http://pkg.FreeBSD.org/freebsd:10:x86:64/latest/packagesite.txz: No address record
Unable to update repository FreeBSD
FreeNAS-9.10-STABLE-201605240427 (64fcd8e)
D
dlavigne
Guest
Can you ping a website (eg google.com) from within the jail? That message looks like you have no DNS from the jail.
D
dlavigne
Guest
Not having name resolution would do it. If you're using DHCP in the jails, add 8.8.8.8 as Nameserver 1 in Network -> Global Configuration. Otherwise, and an entry for 8.8.8.8 in /etc/resolv.conf inside the jail.
