Getting "pkg Not found" Error in Jails
STREBLO
I'm running freenas 9.10, on a machine that was installed fresh from 9.10 and today when I tried to update some old jails I got these errors:
pkg: http://pkg.FreeBSD.org/freebsd:10:x86:64/latest/All/subversion-1.9.4.txz: Not Found
I'm not sure why I'm getting these errors and what I can do about it. I tried making a brand-new jail but when I tried to pkg update && pkg upgrade I got:
Here is what I get with pkg -vv in the brand new jail:
root@podder:/ # pkg -vv
Version				 : 1.9.1
PKG_DBDIR = "/var/db/pkg";
PKG_CACHEDIR = "/var/cache/pkg";
PORTSDIR = "/usr/ports";
INDEXDIR = "";
INDEXFILE = "INDEX-10";
HANDLE_RC_SCRIPTS = false;
DEFAULT_ALWAYS_YES = false;
ASSUME_ALWAYS_YES = false;
REPOS_DIR [
	"/etc/pkg/",
	"/usr/local/etc/pkg/repos/",
PLIST_KEYWORDS_DIR = "";
SYSLOG = true;
ABI = "FreeBSD:10:amd64";
ALTABI = "freebsd:10:x86:64";
DEVELOPER_MODE = false;
VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.bz2";
FETCH_RETRY = 3;
PKG_PLUGINS_DIR = "/usr/local/lib/pkg/";
PKG_ENABLE_PLUGINS = true;
PLUGINS [
DEBUG_SCRIPTS = false;
PLUGINS_CONF_DIR = "/usr/local/etc/pkg/";
PERMISSIVE = false;
REPO_AUTOUPDATE = true;
NAMESERVER = "";
HTTP_USER_AGENT = "pkg/1.9.1";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
UNSET_TIMESTAMP = false;
SSH_RESTRICT_DIR = "";
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
	all-depends = "query %dn-%dv";
	annotations = "info -A";
	build-depends = "info -qd";
	cinfo = "info -Cx";
	comment = "query -i \"%c\"";
	csearch = "search -Cx";
	desc = "query -i \"%e\"";
	download = "fetch";
	iinfo = "info -ix";
	isearch = "search -ix";
	prime-list = "query -e '%a = 0' '%n'";
	leaf = "query -e '%#r == 0' '%n-%v'";
	list = "info -ql";
	noauto = "query -e '%a == 0' '%n-%v'";
	options = "query -i \"%n - %Ok: %Ov\"";
	origin = "info -qo";
	provided-depends = "info -qb";
	raw = "info -R";
	required-depends = "info -qr";
	roptions = "rquery -i \"%n - %Ok: %Ov\"";
	shared-depends = "info -qB";
	show = "info -f -k";
	size = "info -sq";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
CASE_SENSITIVE_MATCH = false;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
SQLITE_PROFILE = false;
WORKERS_COUNT = 0;
READ_LOCK = false;
PLIST_ACCEPT_DIRECTORIES = false;
IP_VERSION = 0;
AUTOMERGE = true;
VERSION_SOURCE = "";
CONSERVATIVE_UPGRADE = true;
PKG_CREATE_VERBOSE = false;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
	"pkg+http",
	"pkg+https",
	"https",
	"http",
	"file",
	"ssh",
	"ftp",
	"ftps",
	"pkg+ssh",
	"pkg+ftp",
	"pkg+ftps",
ALLOW_BASE_SHLIBS = false;
WARN_SIZE_LIMIT = 1048576;
METALOG = "";
Repositories:
  FreeBSD: {
	url			 : "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
	enabled		 : yes,
	priority		: 0,
	mirror_type	 : "SRV",
	signature_type  : "FINGERPRINTS",
	fingerprints	: "/usr/share/keys/pkg"
And did my old jail:
root@pod:/ # pkg -vv
Version				 : 1.7.2
INDEXDIR = "";
REPOS_DIR [
	"/etc/pkg/",
SYSLOG = true;
FETCH_RETRY = 3;
PLUGINS [
PERMISSIVE = false;
NAMESERVER = "";
HTTP_USER_AGENT = "pkg/1.7.2";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
	cinfo = "info -Cx";
	download = "fetch";
	iinfo = "info -ix";
	list = "info -ql";
	raw = "info -R";
	size = "info -sq";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
WORKERS_COUNT = 0;
READ_LOCK = false;
IP_VERSION = 0;
AUTOMERGE = true;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
	"pkg+http",
	"pkg+https",
	"https",
	"http",
	"file",
	"ssh",
	"ftp",
	"ftps",
	"pkg+ssh",
	"pkg+ftp",
	"pkg+ftps",
Repositories:
  FreeBSD: {
	enabled		 : yes,
	priority		: 0,
STREBLO
I'd rather stay away from ports.
Internet is working fine and i cant imagine pkg would be unavailable, are you sure it couldn't be my setup?
Jailer
Not strong, but bad
You have a networking issue. Do you have your jails networking set correctly in the configuration tab? Static IP or DHCP?
Do you have a default gateway defined in your Global configuration tab?
STREBLO
Static ip, I have no connection issues and I can ping the mirror. Yes I have my gateway set.
Jailer
Not strong, but bad
disable vimage and try again.
STREBLO
Not sure what changed but its working now :S
I think I need to do a reinstall, FreeNAS has been acting funky for awhile now, so many bugs <_<
