truenasuser
- Nov 30, 2023
Hello TrueNas community, I'm coming to you today to tell you about my problem, I can't update the pkg files on my system.
I'd like to install an automatic email system, sendMail for example, but every time I place the order, this error would appear :
My kernel versions are not up to date either, I'm still on version 13.1
Here's what it gets me when I type the command "sudo pkg -vv":
positories!
test@truenas:~ $ sudo trueos-upgrade
sudo: trueos-upgrade: command not found
test@truenas:~ $ sudo pkg -vv
Version : 1.20.9
PKG_DBDIR = "/var/db/pkg";
PKG_CACHEDIR = "/var/cache/pkg";
PORTSDIR = "/usr/ports";
INDEXDIR = "";
INDEXFILE = "INDEX-13";
HANDLE_RC_SCRIPTS = false;
DEFAULT_ALWAYS_YES = false;
ASSUME_ALWAYS_YES = false;
REPOS_DIR [
"/etc/pkg/",
"/usr/local/etc/pkg/repos/",
PLIST_KEYWORDS_DIR = "";
SYSLOG = true;
ABI = "FreeBSD:13:amd64";
ALTABI = "freebsd:13:x86:64";
DEVELOPER_MODE = false;
VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.xz";
FETCH_RETRY = 3;
PKG_PLUGINS_DIR = "/usr/local/lib/pkg/";
PKG_ENABLE_PLUGINS = true;
PLUGINS [
DEBUG_SCRIPTS = false;
PLUGINS_CONF_DIR = "/usr/local/etc/pkg/";
PERMISSIVE = false;
REPO_AUTOUPDATE = true;
NAMESERVER = "";
HTTP_USER_AGENT = "pkg/1.20.9";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
UNSET_TIMESTAMP = false;
SSH_RESTRICT_DIR = "";
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
all-depends = "query %dn-%dv";
annotations = "info -A";
build-depends = "info -qd";
cinfo = "info -Cx";
comment = "query -i \"%c\"";
csearch = "search -Cx";
desc = "query -i \"%e\"";
download = "fetch";
iinfo = "info -ix";
isearch = "search -ix";
prime-list = "query -e '%a = 0' '%n'";
prime-origins = "query -e '%a = 0' '%o'";
leaf = "query -e '%#r == 0' '%n-%v'";
list = "info -ql";
noauto = "query -e '%a == 0' '%n-%v'";
options = "query -i \"%n - %Ok: %Ov\"";
origin = "info -qo";
provided-depends = "info -qb";
rall-depends = "rquery %dn-%dv";
raw = "info -R";
rcomment = "rquery -i \"%c\"";
rdesc = "rquery -i \"%e\"";
required-depends = "info -qr";
roptions = "rquery -i \"%n - %Ok: %Ov\"";
shared-depends = "info -qB";
show = "info -f -k";
size = "info -sq";
unmaintained = "query -e '%m = \"ports@FreeBSD.org\"' '%o (%w)'";
runmaintained = "rquery -e '%m = \"ports@FreeBSD.org\"' '%o (%w)'";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
CASE_SENSITIVE_MATCH = false;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
SQLITE_PROFILE = false;
WORKERS_COUNT = 0;
READ_LOCK = false;
IP_VERSION = 0;
AUTOMERGE = true;
VERSION_SOURCE = "";
CONSERVATIVE_UPGRADE = true;
PKG_CREATE_VERBOSE = false;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
"pkg+http",
"pkg+https",
"https",
"http",
"file",
"ssh",
"tcp",
ALLOW_BASE_SHLIBS = false;
WARN_SIZE_LIMIT = 1048576;
METALOG = "";
OSVERSION = 1301000;
IGNORE_OSVERSION = false;
BACKUP_LIBRARIES = false;
BACKUP_LIBRARY_PATH = "/usr/local/lib/compat/pkg";
PKG_TRIGGERS_DIR = "/usr/local/share/pkg/triggers";
PKG_TRIGGERS_ENABLE = true;
AUDIT_IGNORE_GLOB [
AUDIT_IGNORE_REGEX [
COMPRESSION_FORMAT = "";
COMPRESSION_LEVEL = -1;
ARCHIVE_SYMLINK = false;
REPO_ACCEPT_LEGACY_PKG = false;
FILES_IGNORE_GLOB [
FILES_IGNORE_REGEX [
Repositories:
local: {
url : "file:///usr/ports/packages",
enabled : yes,
priority : 0
If you could tell me what to do, I'd follow up on the post every hour.
Thank you very much
positories!
Version : 1.20.9
INDEXDIR = "";
REPOS_DIR [
"/etc/pkg/",
SYSLOG = true;
FETCH_RETRY = 3;
PLUGINS [
PERMISSIVE = false;
NAMESERVER = "";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
cinfo = "info -Cx";
download = "fetch";
iinfo = "info -ix";
list = "info -ql";
raw = "info -R";
size = "info -sq";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
WORKERS_COUNT = 0;
READ_LOCK = false;
IP_VERSION = 0;
AUTOMERGE = true;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
"pkg+http",
"pkg+https",
"https",
"http",
"file",
"ssh",
"tcp",
METALOG = "";
AUDIT_IGNORE_GLOB [
FILES_IGNORE_GLOB [
Repositories:
local: {
enabled : yes,
priority : 0
Thank you very much
