PKG PROBLEMS
truenasuser
Hello TrueNas community, I'm coming to you today to tell you about my problem, I can't update the pkg files on my system.
I'd like to install an automatic email system, sendMail for example, but every time I place the order, this error would appear :
My kernel versions are not up to date either, I'm still on version 13.1
Here's what it gets me when I type the command "sudo pkg -vv":
positories!
test@truenas:~ $ sudo trueos-upgrade
sudo: trueos-upgrade: command not found
test@truenas:~ $ sudo pkg -vv
Version : 1.20.9
PKG_DBDIR = "/var/db/pkg";
PKG_CACHEDIR = "/var/cache/pkg";
PORTSDIR = "/usr/ports";
INDEXDIR = "";
INDEXFILE = "INDEX-13";
HANDLE_RC_SCRIPTS = false;
DEFAULT_ALWAYS_YES = false;
ASSUME_ALWAYS_YES = false;
REPOS_DIR [
"/etc/pkg/",
"/usr/local/etc/pkg/repos/",
PLIST_KEYWORDS_DIR = "";
SYSLOG = true;
ABI = "FreeBSD:13:amd64";
ALTABI = "freebsd:13:x86:64";
DEVELOPER_MODE = false;
VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.xz";
FETCH_RETRY = 3;
PKG_PLUGINS_DIR = "/usr/local/lib/pkg/";
PKG_ENABLE_PLUGINS = true;
PLUGINS [
DEBUG_SCRIPTS = false;
PLUGINS_CONF_DIR = "/usr/local/etc/pkg/";
PERMISSIVE = false;
REPO_AUTOUPDATE = true;
NAMESERVER = "";
HTTP_USER_AGENT = "pkg/1.20.9";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
UNSET_TIMESTAMP = false;
SSH_RESTRICT_DIR = "";
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
all-depends = "query %dn-%dv";
annotations = "info -A";
build-depends = "info -qd";
cinfo = "info -Cx";
comment = "query -i \"%c\"";
csearch = "search -Cx";
desc = "query -i \"%e\"";
download = "fetch";
iinfo = "info -ix";
isearch = "search -ix";
prime-list = "query -e '%a = 0' '%n'";
prime-origins = "query -e '%a = 0' '%o'";
leaf = "query -e '%#r == 0' '%n-%v'";
list = "info -ql";
noauto = "query -e '%a == 0' '%n-%v'";
options = "query -i \"%n - %Ok: %Ov\"";
origin = "info -qo";
provided-depends = "info -qb";
rall-depends = "rquery %dn-%dv";
raw = "info -R";
rcomment = "rquery -i \"%c\"";
rdesc = "rquery -i \"%e\"";
required-depends = "info -qr";
roptions = "rquery -i \"%n - %Ok: %Ov\"";
shared-depends = "info -qB";
show = "info -f -k";
size = "info -sq";
unmaintained = "query -e '%m = \"ports@FreeBSD.org\"' '%o (%w)'";
runmaintained = "rquery -e '%m = \"ports@FreeBSD.org\"' '%o (%w)'";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
CASE_SENSITIVE_MATCH = false;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
SQLITE_PROFILE = false;
WORKERS_COUNT = 0;
READ_LOCK = false;
IP_VERSION = 0;
AUTOMERGE = true;
VERSION_SOURCE = "";
CONSERVATIVE_UPGRADE = true;
PKG_CREATE_VERBOSE = false;
AUTOCLEAN = false;
DOT_FILE = "";
REPOSITORIES {
VALID_URL_SCHEME [
"pkg+http",
"pkg+https",
"https",
"http",
"file",
"ssh",
"tcp",
ALLOW_BASE_SHLIBS = false;
WARN_SIZE_LIMIT = 1048576;
METALOG = "";
OSVERSION = 1301000;
IGNORE_OSVERSION = false;
BACKUP_LIBRARIES = false;
BACKUP_LIBRARY_PATH = "/usr/local/lib/compat/pkg";
PKG_TRIGGERS_DIR = "/usr/local/share/pkg/triggers";
PKG_TRIGGERS_ENABLE = true;
AUDIT_IGNORE_GLOB [
AUDIT_IGNORE_REGEX [
COMPRESSION_FORMAT = "";
COMPRESSION_LEVEL = -1;
ARCHIVE_SYMLINK = false;
REPO_ACCEPT_LEGACY_PKG = false;
FILES_IGNORE_GLOB [
FILES_IGNORE_REGEX [
Repositories:
local: {
url : "file:///usr/ports/packages",
enabled : yes,
priority : 0
If you could tell me what to do, I'd follow up on the post every hour.
Thank you very much
That's not a problem, it's a design decision. Messing with the base system is entirely unsupported. All updates are exclusively via iX's updates.
truenasuser
Thanks for your response Ericloewe
Okay, but I can't install any software on it, I always get the same error code.
How do I fix this?
Patrick M. Hausen
Any application you want to install with pkg has to live in a jail. You can use pkg just fine like that but not on the NAS host system. Also you can easily create a jail with a supported FreeBSD version, i.e. 13.2.
Are you running an old version of FreeNAS? if you are running TrueNAS why aren't you posting in the TrueNAS CORE forum? Just curious because that happens quite frequently ...
truenasuser
Hey Patrick, Thanks you for your response.
I use version TrueNAS-13.0-U5.3 of TrueNAS. I d'ont posting in the TrueNAS Core forum because i'm new user.
I need to be informed.
Regarding your answer, can you give me the procedure to follow?
Thanks !
Patrick M. Hausen
But you are not running FreeNAS - but TrueNAS CORE 13.0-U5.3, right? There's the TrueNAS CORE section for that.
Are you familiar with FreeBSD jails? You seem to know your way around installing applications with pkg?
There is a section labelled "Jails" in the UI. Create a VNET jail with FreeBSD 13.2. The corresponding documentation section is here.
truenasuser
Thanks Patrick,
I get this message when I try to create a Jail :
Erreur: Traceback (most recent call last):
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] Name does not resolve
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 358, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x81e037fd0>: Failed to establish a new connection: [Errno 8] Name does not resolve
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x81e037fd0>: Failed to establish a new connection: [Errno 8] Name does not resolve'))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 139, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1247, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 827, in releases_choices
choices = {str(k): str(k) for k in ListableReleases(remote=remote)}
File "/usr/local/lib/python3.9/site-packages/iocage_lib/release.py", line 47, in __init__
self.eol_list = IOCFetch.__fetch_eol_check__()
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_fetch.py", line 114, in __fetch_eol_check__
req = requests.get(_eol)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x81e037fd0>: Failed to establish a new connection: [Errno 8] Name does not resolve'))
Do you have solutions ?
Seems you probably need to ensure you have your network settings properly defined under Network | Global Configuration
You should have nameserver(s) set and a default gateway set there for jails to work correctly.
