So I completed the update from 11.2-U5 to 11.2-U7 and when I run pkg update I get this:
I have faced this problem in the past, and from what I understand the jail thinks its on 11.2 and the update server being queried has updates for 11.3. Do I understand correctly?
Oddly enough, if I select "n" to not update, then run pkg update again, it just says there are no updates. I forget all relevant files involved, but here's the 2 I do remember were pertinent last time:
It's been quite a while since I've checked for updates on my jails so I'm pretty surprised that there are none. For example, my plex jail shows no updates, but I'm running version 1.18.2.1973_1:
and freshports shows:
1.18.2.2041
I believe there was a way to download releases for iocage from the CLI but I forget what that was and how to do it, and I don't recall in the past that the "iocage list" command showing this:
Normally it would have said 11.2-RELEASE-P5 or something similar, which I assumed was patch level (11.2-U5).
So because of that I think is why I'm getting this:
To ignore this error set IGNORE_OSVERSION=yes - package: 1103000 - running kernel: 1102000 Ignore the mismatch and continue? [Y/n]: n pkg: repository FreeBSD contains packages for wrong OS version: FreeBSD:11:amd64 Processing entries: 100% Unable to update repository FreeBSD Error updating repositories! root@dns_1:~ # uname -a FreeBSD dns_1 11.2-STABLE FreeBSD 11.2-STABLE #0 r325575+c9231c7d6bd(HEAD): Mon Nov 18 22:46:47 UTC 2019 root@nemesis:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64 root@dns_1:~ # uname -r 11.2-STABLE
root@dns_1:~ # cat /etc/pkg/FreeBSD.conf # $FreeBSD: releng/11.2/etc/pkg/FreeBSD.conf 333474 2018-05-10 23:58:33Z gjb $ # # To disable this repository, instead of modifying or removing this file, # create a /usr/local/etc/pkg/repos/FreeBSD.conf file: # # mkdir -p /usr/local/etc/pkg/repos # echo "FreeBSD: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf # FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly", mirror_type: "srv", signature_type: "fingerprints", fingerprints: "/usr/share/keys/pkg", enabled: yes }
root@dns_1:~ # cat /usr/local/etc/pkg.conf # System-wide configuration file for pkg(8) # For more information on the file format and # options please refer to the pkg.conf(5) man page # Note: you don't need to have a pkg.conf file. Many installations # will work well with no pkg.conf at all or with an empty pkg.conf # (other than comment lines). You can also override any of these # settings from the environment. # Configuration options -- default values. #PKG_DBDIR = "/var/db/pkg"; #PKG_CACHEDIR = "/var/cache/pkg"; #PORTSDIR = "/usr/ports"; #INDEXDIR = ""; #INDEXFILE = "INDEX-10"; # Autogenerated #HANDLE_RC_SCRIPTS = false; #DEFAULT_ALWAYS_YES = false; #ASSUME_ALWAYS_YES = false; #REPOS_DIR [ # "/etc/pkg/", # "/usr/local/etc/pkg/repos/", #] #PLIST_KEYWORDS_DIR = ""; #SYSLOG = true; #ABI = "freebsd:10:x86:64"; # Autogenerated #DEVELOPER_MODE = false; #VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.bz2"; #FETCH_RETRY = 3; #PKG_PLUGINS_DIR = "/usr/local/lib/pkg/"; #PKG_ENABLE_PLUGINS = true; #PLUGINS [ #] #DEBUG_SCRIPTS = false; #PLUGINS_CONF_DIR = "/usr/local/etc/pkg/"; #PERMISSIVE = false; #REPO_AUTOUPDATE = true; #NAMESERVER = ""; #HTTP_USER_AGENT = "Custom_User_Manager"; #EVENT_PIPE = ""; #FETCH_TIMEOUT = 30; #UNSET_TIMESTAMP = false; #SSH_RESTRICT_DIR = ""; #PKG_ENV { #} #PKG_SSH_ARGS = ""; #DEBUG_LEVEL = 0; #ALIAS { #} #CUDF_SOLVER = ""; #SAT_SOLVER = ""; #RUN_SCRIPTS = true; #CASE_SENSITIVE_MATCH = false; #IP_VERSION = 0 # Sample alias settings ALIAS : { all-depends: query %dn-%dv, annotations: info -A, build-depends: info -qd, cinfo: info -Cx, comment: query -i "%c", csearch: search -Cx, desc: query -i "%e", download: fetch, iinfo: info -ix, isearch: search -ix, prime-list: "query -e '%a = 0' '%n'", prime-origins: "query -e '%a = 0' '%o'", leaf: "query -e '%#r == 0' '%n-%v'", list: info -ql, noauto = "query -e '%a == 0' '%n-%v'", options: query -i "%n - %Ok: %Ov", origin: info -qo, provided-depends: info -qb, rall-depends: rquery %dn-%dv, raw: info -R, rcomment: rquery -i "%c", rdesc: rquery -i "%e", required-depends: info -qr, roptions: rquery -i "%n - %Ok: %Ov", shared-depends: info -qB, show: info -f -k, size: info -sq, }
root@pms:~ # pkg info plexmediaserver-plexpass plexmediaserver-plexpass-1.18.1.1973_1 Name : plexmediaserver-plexpass Version : 1.18.1.1973_1 Installed on : Thu Oct 31 06:58:06 2019 PDT Origin : multimedia/plexmediaserver-plexpass Architecture : FreeBSD:11:amd64 Prefix : /usr/local Categories : multimedia Licenses : Maintainer : feld@FreeBSD.org WWW : https://plex.tv Comment : Plex Media Server component Options : RELAY : on Annotations :
1.18.2.2041
FreshPorts -- multimedia/plexmediaserver-plexpass: Plex Media Server component
Plex Media Server is used to host the content and plugins that are then streamed to Plex Media Center and Plex mobile app clients, either on the same machine, the same local area network, or over the Internet. Content may be transcoded by the server before it's streamed in order to reduce...
www.freshports.org
| 8 | pms | up | 11.2-RELEASE |
root@pms:~ # freebsd-update fetch Looking up update.FreeBSD.org mirrors... 3 mirrors found. Fetching metadata signature for 11.2-STABLE from update4.freebsd.org... failed. Fetching metadata signature for 11.2-STABLE from update2.freebsd.org... failed. Fetching metadata signature for 11.2-STABLE from update1.freebsd.org... failed. No mirrors remaining, giving up.
