Hi, at first thank you for your help.
If I run this cmd in Putty I get the following result.
root@truenas[~]# iocage activate rep-seniorenmutter
File "/usr/local/lib/python3.8/logging/config.py", line 563, in configure
handler = self.configure_handler(handlers[name])
File "/usr/local/lib/python3.8/logging/config.py", line 744, in configure_hand ler
result = factory(**kwargs)
File "/usr/local/lib/python3.8/logging/handlers.py", line 148, in __init__
BaseRotatingHandler.__init__(self, filename, mode, encoding, delay)
File "/usr/local/lib/python3.8/logging/handlers.py", line 55, in __init__
logging.FileHandler.__init__(self, filename, mode, encoding, delay)
File "/usr/local/lib/python3.8/logging/__init__.py", line 1143, in __init__
StreamHandler.__init__(self, self._open())
File "/usr/local/lib/python3.8/logging/__init__.py", line 1172, in _open
return open(self.baseFilename, self.mode, encoding=self.encoding)
FileNotFoundError: [Errno 2] No such file or directory: '/var/log/iocage.log'
The above exception was the direct cause of the following exception:
File "/usr/local/bin/iocage", line 10, in <module>
sys.exit(cli())
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 764, in __ca ll__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1134, in inv oke
Command.invoke(self, ctx)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 956, in invo ke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 555, in invo ke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/iocage_cli/__init__.py", line 223 , in cli
logger = IOCLogger()
File "/usr/local/lib/python3.8/site-packages/iocage_cli/__init__.py", line 148 , in __init__
logging.config.dictConfig(default_logging)
File "/usr/local/lib/python3.8/logging/config.py", line 808, in dictConfig
dictConfigClass(config).configure()
File "/usr/local/lib/python3.8/logging/config.py", line 570, in configure
raise ValueError('Unable to configure handler '
ValueError: Unable to configure handler 'file'
root@truenas[~]#
What did you mean with replication? At the moment I replication tasks with Snapshots. Is that the Same?
