jail redundacy
Leonard Lassen
Okay, thank you :) What did you mean with "the dataset in question"? Activates iocage activate every of my backups?
Leonard Lassen
I'm still struggling with the description that you are running jails from two separate pools on the same TrueNAS server, and then replicating these to another TrueNAS server with two pools and trying to enable both of these. If that were possible, you'd have 4 Nextcloud jails running across 2 TrueNAS servers!
It are two Servers a main and a backup server, two machines.
adrianwi
But you keep on saying you have two pools in each machine?
Patrick M. Hausen
You have a backup somepool/iocage/... with a dozen or so sub-datasets that contain all your jails. It's read-only, so you cannot run the jails.
In case your primary machine goes up in smoke you
  • set the somepool/iocage dataset on the backup machine to read-write
  • use iocage activate somepool to tell iocage that this is now the active running jail dataset
  • use the UI or iocage list, iocage start, ... to start your jails on the backup system
iocage activate tells the system that this is now where your live jails reside. You cannot backup to this dataset anymore, because you cannot backup/replicate to live running jails. You only do this in case of an emergency to make the backup jails "runnable".
Afterwards you need to repair your failed system and then either create a replication in the other direction, essentially switching the roles of active and backup - or restore the jails manually via the command line.
