I have a XenServer pool I am testing with FreeNas 8.0 and iSCSI. When the initiator name field is set to ALL everything works, but when I want to set this up to be restrictive I can only get things to fly with one XenServer.
The problem seems to be with the comma seperated value for iqn name. If I add a single iqn each server can connect just fine. But when I add the two iqns with a comma between them (no space as per the documentation) neither host can connect. Is the documentation wrong, Is this a bug I should report, or am I missing something painfully obvious?
