I'm hoping someone can point out something simple I'm overlooking on this one. I've got new hardware and I'm running 11.2 rc1. I had a couple of old pools I had imported and were not working well due to block size so I decided to reconfigure the pools and make new iscsi targets.
Currently I have 3 targets, one for windows and two for vmware (esxi 6.7 U1). All sharing the same portal and initiator. Windows can see and use any of the targets without problems. VMware can see all the targets but only lists the windows target as a device. The extents are identical. I am not using port bindng. In vcenter the paths are detected but have a status of dead. Screen shot of that attached.
when I do a rescan vmkernal.log shows
I thought it could be network related but the old targets worked well enough in that regard and I am not sure what to do next.
Edit:
I have 2 pools for vmware storage each with 6 Seagate SAS drives in a mirrored stripe and a single zvol on each for use as a target. Standard GUI creation with no options changed.
ESXI host is a Supermicro X9DRi-LN4 with dual 2660v2 and 128Gb RAM using an intel 10G x550 plus whats listed as an Intel 82599EB 10-Gigabit SFP+ that I was pretty sure was a MELLANOX CONNECTX-2.
NAS is in my sig and besides hard drives the only other addition was a Chelsio 10GB 2-Ports SFP+ card.
Currently iscsi network is not yet isolated and everything runs on a Netgear XS728T.
2018-11-12T14:57:59.641Z cpu8:2099951 opID=81979b41)World: 11943: VC opID RescanStorageFormMediator-apply-862-ngc:70000188-ab-23-3c58 maps to vmkernel opID 81979b41 2018-11-12T14:57:59.641Z cpu8:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.641Z cpu8:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T1:L1 is not registered (no active paths) 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.641Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T2:L1 is not registered (no active paths) 2018-11-12T14:57:59.737Z cpu10:2097625)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.737Z cpu10:2097625)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.737Z cpu19:2097622)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.737Z cpu19:2097622)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.737Z cpu10:2097625)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.737Z cpu10:2097625)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.737Z cpu19:2097622)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.737Z cpu19:2097622)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T1:L1 is not registered (no active paths) 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.738Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T2:L1 is not registered (no active paths) 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T1:L1 is not registered (no active paths) 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T2:L1 is not registered (no active paths) 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T1:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T1:L1 is not registered (no active paths) 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C0:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_determineStatus:572: VMW_SATP_ALUA:Unknown Check condition 0/2 0x5 0x20 0x0. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: VMW_SATP_ALUA: satp_alua_issueCommandOnPath:786: Probe cmd 0xa3 failed for path "vmhba64:C1:T2:L1" (0x5/0x20/0x0). Check if failover mode is still ALUA. 2018-11-12T14:57:59.874Z cpu4:2099951 opID=81979b41)WARNING: NMP: nmpPathClaimEnd:1206: Device, seen through path vmhba64:C1:T2:L1 is not registered (no active paths) 2018-11-12T14:58:00.692Z cpu11:2111033)WARNING: NFS: 1227: Invalid volume UUID naa.6589cfc000000ed8f4c4ed6e16600ce9:2 2018-11-12T14:58:00.698Z cpu11:2111033)FSS: 6092: No FS driver claimed device 'naa.6589cfc000000ed8f4c4ed6e16600ce9:2': No filesystem on the device 2018-11-12T14:58:01.697Z cpu0:2097211)ScsiDeviceIO: 3068: Cmd(0x459a4cadfd80) 0x1a, CmdSN 0x199e from world 0 to dev "t10.SanDisk_Cruzer_Fit______4C532000020629114362" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x24 0x0. 2018-11-12T14:58:02.122Z cpu23:2099952 opID=d24ec10f)World: 11943: VC opID RescanStorageFormMediator-apply-863-ngc:70000188-e-9d-3c62 maps to vmkernel opID d24ec10f 2018-11-12T14:58:02.122Z cpu23:2099952 opID=d24ec10f)VC: 4616: Device rescan time 419 msec (total number of devices 6) 2018-11-12T14:58:02.122Z cpu23:2099952 opID=d24ec10f)VC: 4619: Filesystem probe time 1402 msec (devices probed 5 of 6) 2018-11-12T14:58:02.122Z cpu23:2099952 opID=d24ec10f)VC: 4621: Refresh open volume time 37 msec
Edit:
