Hi guys
I've been racking my brain here for the last 10 hours or so... wondering if you can help me:
setup:
1 x DL380 G9 - head of VMWARe for resource
1 x DL380 G7 - for storage - TrueNAS
Confirmed communication as i can ping each other between trueNAS and VMware on the 10 network.
I created an ISCSI share using the wizard and using the DISK (not pools) - added it to VMware via the 10.10.10.10 address. It sees the Disk fine which is 3.1TB. I try to create the VMFS datastore and i get the following: (it fails in vmware with cannot configure host)
2021-03-08T11:25:31.602Z cpu3:2102603)iscsi_vmk: iscsivmk_ConnNetRegister:2219: socket 0x4310337a4ba0 network tracker id 256862042 tracker.iSCSI.10.10.10.10 associated
2021-03-08T11:25:31.854Z cpu3:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:880: vmhba64:CH:0 T:1 CN:0: iSCSI connection is being marked "ONLINE"
2021-03-08T11:25:31.854Z cpu3:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:881: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:31.854Z cpu3:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:882: Conn [CID: 0 L: 10.10.10.1:50926 R: 10.10.10.10:3260]
2021-03-08T11:25:31.861Z cpu12:2102200)NMP: nmp_ThrottleLogForDevice:3818: last error status from device naa.6589cfc000000b7b531a5f4afb23402c repeated 61 times
2021-03-08T11:25:31.861Z cpu12:2102200)NMP: nmp_ThrottleLogForDevice:3872: Cmd 0x84 (0x459b01674c80, 0) to dev "naa.6589cfc000000b7b531a5f4afb23402c" on path "vmhba64:C0:T1:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0x6 0x29 0x7. Act:NONE
2021-03-08T11:25:31.861Z cpu12:2102200)ScsiDeviceIO: 3448: Cmd(0x459b01674c80) 0x84, CmdSN 0x197d from world 0 to dev "naa.6589cfc000000b7b531a5f4afb23402c" failed H:0x0 D:0x2 P:0x0 Valid sense da ta: 0x6 0x29 0x7.
2021-03-08T11:35:13.437Z cpu41:2098058)DVFilter: 6053: Checking disconnected filters for timeouts
2021-03-08T11:39:00.594Z cpu3:2102200)ScsiDeviceIO: 3469: Cmd(0x45bb0104edc0) 0x85, CmdSN 0x16 from world 2099800 to dev "naa.6589cfc000000b7b531a5f4afb23402c" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x20 0x0.
[root@localhost:~] tail -n100 /var/log/vmkernel.log
2021-03-08T11:25:05.449Z cpu0:2102200)WARNING: iscsi_vmk: iscsivmk_ConnReceiveAtomic:525: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:05.449Z cpu0:2102200)WARNING: iscsi_vmk: iscsivmk_ConnReceiveAtomic:526: Conn [CID: 0 L: 10.10.10.1:55223 R: 10.10.10.10:3260]
2021-03-08T11:25:05.449Z cpu0:2102200)iscsi_vmk: iscsivmk_ConnRxNotifyFailure:1235: vmhba64:CH:0 T:1 CN:0: Connection rx notifying failure: Failed to Receive. State=Online
2021-03-08T11:25:05.449Z cpu0:2102200)iscsi_vmk: iscsivmk_ConnRxNotifyFailure:1236: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:05.449Z cpu0:2102200)iscsi_vmk: iscsivmk_ConnRxNotifyFailure:1237: Conn [CID: 0 L: 10.10.10.1:55223 R: 10.10.10.10:3260]
2021-03-08T11:25:05.449Z cpu27:2097899)WARNING: iscsi_vmk: iscsivmk_StopConnection:699: vmhba64:CH:0 T:1 CN:0: iSCSI connection is being marked "OFFLINE" (Event:6)
2021-03-08T11:25:05.449Z cpu27:2097899)WARNING: iscsi_vmk: iscsivmk_StopConnection:700: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:05.449Z cpu27:2097899)WARNING: iscsi_vmk: iscsivmk_StopConnection:701: Conn [CID: 0 L: 10.10.10.1:55223 R: 10.10.10.10:3260]
2021-03-08T11:25:05.454Z cpu27:2102527)WARNING: NMP: nmp_DeviceRequestFastDeviceProbe:237: NMP device "naa.6589cfc000000b7b531a5f4afb23402c" state in doubt; requested fast path state update...
2021-03-08T11:25:06.450Z cpu27:2102527)WARNING: NMP: nmp_DeviceRequestFastDeviceProbe:237: NMP device "naa.6589cfc000000b7b531a5f4afb23402c" state in doubt; requested fast path state update...
2021-03-08T11:25:07.449Z cpu27:2102527)WARNING: NMP: nmp_DeviceRequestFastDeviceProbe:237: NMP device "naa.6589cfc000000b7b531a5f4afb23402c" state in doubt; requested fast path state update...
2021-03-08T11:25:08.233Z cpu3:2102603)iscsi_vmk: iscsivmk_ConnNetRegister:2191: socket 0x4310335a8200 network resource pool netsched.pools.persist.iscsi associated
2021-03-08T11:25:08.233Z cpu3:2102603)iscsi_vmk: iscsivmk_ConnNetRegister:2219: socket 0x4310335a8200 network tracker id 256862042 tracker.iSCSI.10.10.10.10 associated
2021-03-08T11:25:08.419Z cpu27:2102527)NMP: nmp_ThrottleLogForDevice:3801: last error status from device naa.6589cfc000000b7b531a5f4afb23402c repeated 640 times
2021-03-08T11:25:08.447Z cpu27:2102527)WARNING: NMP: nmp_DeviceRequestFastDeviceProbe:237: NMP device "naa.6589cfc000000b7b531a5f4afb23402c" state in doubt; requested fast path state update...
2021-03-08T11:25:08.487Z cpu4:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:880: vmhba64:CH:0 T:1 CN:0: iSCSI connection is being marked "ONLINE"
2021-03-08T11:25:08.487Z cpu4:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:881: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:08.487Z cpu4:2102603)WARNING: iscsi_vmk: iscsivmk_StartConnection:882: Conn [CID: 0 L: 10.10.10.1:16387 R: 10.10.10.10:3260]
2021-03-08T11:25:08.490Z cpu21:2102201)Uplink: 5853: vmnic4: TSO packet has large MSS (8948) plus L7 offset (66), which can't be fit into MTU (1500)
2021-03-08T11:25:08.727Z cpu21:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:08.997Z cpu21:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:09.327Z cpu21:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:09.777Z cpu21:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:10.467Z cpu21:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:11.637Z cpu12:2102201)Uplink: 5887: vmnic4: Non TSO L2 payload size exceeds uplink MTU. FrameLen: 9014, L3 header offset: 14
2021-03-08T11:25:13.235Z cpu12:2102200)WARNING: iscsi_vmk: iscsivmk_ConnReceiveAtomic:522: vmhba64:CH:0 T:1 CN:0: Failed to receive data: Connection reset by peer
2021-03-08T11:25:13.235Z cpu12:2102200)WARNING: iscsi_vmk: iscsivmk_ConnReceiveAtomic:525: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
2021-03-08T11:25:13.235Z cpu12:2102200)WARNING: iscsi_vmk: iscsivmk_ConnReceiveAtomic:526: Conn [CID: 0 L: 10.10.10.1:16387 R: 10.10.10.10:3260]
2021-03-08T11:25:13.235Z cpu12:2102200)iscsi_vmk: iscsivmk_ConnRxNotifyFailure:1235: vmhba64:CH:0 T:1 CN:0: Connection rx notifying failure: Failed to Receive. State=Online
2021-03-08T11:25:13.235Z cpu12:2102200)iscsi_vmk: iscsivmk_ConnRxNotifyFailure:1236: Sess [ISID: 00023d000001 TARGET: iqn.2005-10.org.freenas.ctl:test TPGT: 1 TSIH: 0]
Does that in a loop until the creation fails with : Cannot change the host configuration.
VMWare events keep saying it losing both paths when it tries to create the datastore - i dont know whats going on... why can it pick the storage up but not do anything with it? then lose connectivity and offline it. I've not told TrueNAS to make it read only either.
I've also trying to create the pool, then the zvol and it does the same thing. I've also tried going into vmware CLI and try formatting it to msdos but that fails to commit.
It's as if it fails when trying to write to the disk or communicate with it.
Any ideas?
Thanks
setup:
- 2 x 10Gbit Cards
- 2 x DACS going to 10G switch
- ISCSI network setup with VMkernel ports 10.10.10.1 and .2 (/24)setup (Round robin)
- LAGG setup to include both 10Gbit ports
- VLAN 100 created including the 2 10G ports - IP 10.10.10.10/24
NOTE: all interfaces are using MTU: 9000Confirmed communication as i can ping each other between trueNAS and VMware on the 10 network.
Any ideas?
Thanks
