nfriedly
- Jan 15, 2016
Hi, I just set up my first freeNAS today, and I was having trouble with it - I couldn't actually mount the CIFS share, and I also couldn't turn on the SMART service. Some fooling around on the command line and I learned that I have to include -d sat with my smartctl commands. After that, I was able to get this output from a short test:
[root@freenas] ~# smartctl -d sat -A /dev/da0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
1 Raw_Read_Error_Rate 0x000f 066 065 006 Pre-fail Always - 4036414
3 Spin_Up_Time 0x0003 095 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 045 Pre-fail Always - 41272
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 1
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 062 062 040 Old_age Always - 38 (Min/Max 16/38)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 7
194 Temperature_Celsius 0x0022 038 040 000 Old_age Always - 38 (0 16 0 0 0)
195 Hardware_ECC_Recovered 0x001a 021 020 000 Old_age Always - 4036414
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2 (142 95 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1092944
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2943470
This is a brand new Seagate NAS HDD ST6000VN0021 connected via one of these: http://www.tripplite.com/products/model-print/mid/5652 (which is presumably why I need to specify the device type and perhaps also the source of the problems with my SMART service.)
The other two drives are WD Reds that report 0's for the Raw_Read_Error_Rate and don't have a line for Hardware_ECC_Recovered.
So, my main question is: is that Seagate drive bad? Should I just send it back and ask for a replacement?
I'm also curious about the SMART service and getting it to work with my USB drive bays. Anyone have any advice there? (The USB bays are because my "server" is actually a laptop that I had sitting around with a ton of RAM in it.)
