I'm rebuilding my FreeNAS from scratch and I read about iohyve and I setupped successfuly a VM.
In the past I was using the jail from Freenas instead of pluging because I liked the customisation and I was able to upgrade myself my setup.
If you had to redo it from 0 for your jail or plugin will you use start using iohyve ?
I will use FreeBSD for my new jail/iohyve for my new setup.
Does the last version of FreeNas 9.10.2 is stable for iohyve or you recommend to wait for FreeNas 10 ?
For performance side does jail is faster then iohyve for the same Unix ?
I'm checking the pro's and con's ;)
Thanks
Thanks
