Since the update to 9.10.2 earlier today my VMs no longer worked, so I'm trying to get re-setup with iohyve.
I'm following the steps I've found and when I get to the pool setup it's kicking out an error that essentially prevents me from going any further:
Any thoughts on where I can go to get going with this?
[root@freenas] ~# iohyve setup pool=thedata kmod=1 net=igb0 Setting up iohyve pool... /usr/local/sbin/iohyve: setup_freenas: not found Loading kernel modules... bridge0 is already enabled on this machine... Setting up correct sysctl value... net.link.tap.up_on_open: 0 -> 1
