Hey guys,
I have zoneminder recording videos to a pool called "cams" on a single hard drive (strip).
It all starts with this warning:
then I get this one:
and after these emails My FreeNAS box becomes unresponsive and I have to do a hard reset to get it back to work. then the history repeats again and again.
I have replaced the hard drive but no luck. admittedly I have been using 10 year old WD blue that I have laying around.
Howerver I have run extended SMART tests and they come back with no errors.
The only strange thing I have noiced is that this particular hard drive is always about 41 degrees, while my other HDD are about 30 degrees Celsius.
Any idea of what could be happening?
I am thinking of getting a new HDD and sata cable. Would I be wasting my money if I do?
this is the output of SMART test:
Thanks in advance
New alerts: * New feature flags are available for volume cams. Refer to the "Upgrading a ZFS Pool" subsection in the User Guide "Installing and Upgrading" chapter and "Upgrading" section for more instructions.
Gone alerts: * The volume cams state is UNAVAIL: One or more devices are faulted in response to IO failures. * New feature flags are available for volume cams. Refer to the "Upgrading a ZFS Pool" subsection in the User Guide "Installing and Upgrading" chapter and "Upgrading" section for more instructions.
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Blue (SATA) Device Model: WDC WD5000AAKS-60A7B2 Serial Number: WD-WCAT00881846 LU WWN Device Id: 5 0014ee 2aee34b1a Firmware Version: 03.03B03 User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 2.5, 3.0 Gb/s Local Time is: Thu Feb 7 08:53:54 2019 AWST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 8700) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 103) minutes. SCT capabilities: (0x303f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 172 160 021 Pre-fail Always - 4391 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1391 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0 9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 11766 10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 11 Calibration_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1387 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 17180131332 190 Airflow_Temperature_Cel 0x0022 058 053 045 Old_age Always - 42 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 96 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1391 194 Temperature_Celsius 0x0022 105 100 000 Old_age Always - 42 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 11766 - # 2 Short offline Completed without error 00% 0 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Thanks in advance
