kroko
- Mar 9, 2015
This forum has been a really good resource, learned a lot from it. Thank you!
I have question about choice of logicboard and setup in general based on planned usage.
1)
Intel S1200V3RPL http://ark.intel.com/products/71384/Intel-Server-Board-S1200V3RPL
vs
Supermicro X10SLH-F
Where I’m at delivery time for Asrock C226 WS or Asrock E3C226D2I is ~month. As we are running out of space and some of our data even isn't backuped any more this is ASAP. :)
In case of second one I’d have to change RAM, based on a sticky note in this forum.
I can find many Supermicro users here (sometimes feels like Supermicro uuber alles :)), but have not found any discussion on S1200V3RPL.
Many praise Supermicro's IPMI. But Intel has it's counterpart Intel RMM http://www.intel.com/content/www/us/en/server-management/intel-remote-management-module.html which can be attached to this board if needed. Same stuff - low level monitoring and controlling through ethernet.
And that kind of seems the only "difference" between those boards. It feels Intel is a robust alternative.
And as I’m ready-out-of-box computer user I wasn't able in last days (reading 24/7 about ZFS, simulating failed drives in virtualbox etc) to cover that much of information.
Any advice between these two logicboards? Any Intel user here?
2) Setup
Storage:
6x WD60EFRX WD Red 6TB SATA 6Gb/s 64MB
LOBO:
Intel S1200V3RPL + Intel AXXRMM4
CPU:
Intel Pentium Dual Core G3420 (ECC supported)
Core i3 Intel Core i3-4330 3.5Ghz/4MB (ECC supported)
(switching from G3420/G3460 to i3-4330. same Hz, but bigger CPU cache and a touch of multithreading)
RAM:
4x8GB KINGSTON KVR16LE11/8 SERVER MEMORY 8GB PC12800 DDR3/ECC
PSU:
CTG-600-80P CHIEFTEC A-80 PSU 600W
USB:
2x KINGSTON DTDUO3/16GB 16GB (DT microDuo USB3.0)
CASE + COOLER:
Cooler Master computer case Silencio 452 black
ZM-F2 FDB(SF) ZALMAN 92MM FDB CASE FAN
UPS
Eaton 5S1000i via USB NUT
Usage 1:
RAIDZ-2.After ~year will be expanded to 6 HDDs
A second backup machine matching this one so no “mirroring” is done in RAID, but because of backuping.
No encryption
No jails
APF, CIFS, SFTP, FTP shares + one NFS share.
Every day APF and CIFS shares used (5 OSX, 3 MSW machines), NFS to connect to webserver.
1 NIC used for everyday sharing
1 NIC used for mounting NAS on webserver via NFS exclusively
1 NIC (AXXRMM4) for Intel RMM.
Usage 2:
It will be used every day as a studio “data archive” machine. Designing, coding and animations. Thus lots of projects that take gigabytes per project. Once project is ended it goes into archive. Things are reusable, so we use this archive. Containing photoshop, illustrator, aftereffects, storage for raw videos etc. Storing assets for rendering (like texture files libraries). And of course also documents.
Usage 3:
We have webpage development server in our studio, NAS will sit right next to it. Apart from other things it also runs a vhost for owncloud. Owncloud is for project/files we actually currently work on, so much more busy read/write, sharing with clients, uploads from clients.
NAS? well.. the owncloud data dir actually will be physically on NAS, mounted via NFS in local gigabit ethernet (I'm using HP 1410 switches everywhere). I have setup this approach already with a test installation of FreeNAS inside virtualbox, tested access restrictions for server to connect only. For permissions creating matching IDs and GIDs is easy (even so as we run apache vhost using mpm_itk_module). Although I have not run any read/write tests yet, all smooth, all works.
All the “computation” apart from file r/w is done on server machine, not NAS. Server, not NAS, also stores and manages owncloud DB. The link (NFS speed) of course is not the “fastest way r/w wise”, but … we get tons of space for owncloud files and we separate logic from file storage.
Usage 4:
It is backup location (rsync) for development servers code / database.
Given this setup and usage is anything you could comment? :) Ditching Pentium and from a start going i3 CPU? Archive will not be busy, owncloud data stored on NAS however will, but also only for files I/O.
Many thanks in advance,
kroko
1)
vs
Supermicro X10SLH-F
2) Setup
Storage:
LOBO:
CPU:
RAM:
PSU:
USB:
CASE + COOLER:
UPS
Usage 1:
RAIDZ-2.
No encryption
No jails
Usage 2:
Usage 3:
Usage 4:
kroko
