Instaltion help
Archerxplex
When I start the install I get to the blue screen with the gray box and the arrow keys dont work what can I do to get it to work?
Redcoat
Use the <Tab> key.
Redcoat
Then no idea here...
Heracles
Maybe should you plug your keyboard in ?
Try a different port, a different keyboard....
Jailer
Not strong, but bad
No that doesnt work I can get to the screen where I select the drive but I can't pick one its almost as if it mapped my keyboard wrong
Use the space bar to select a menu item.
Archerxplex
Archerxplex
I've also relaunched it countless times and it keeps coming with the same issue I've tried doing it from USB and from a CD
Archerxplex
These are the keys that allow me to select ok (7,Q,Y,I,A, and space bar) also if I do (U+I and H+J) It also selects ok but (G+H) Moves it from ok to cancel
SweetAndLow
Sweet'NASty
space bar should check the box for your disk when it's highlighted.
Redcoat
Perhaps you should tell us something about the box you are booting up to install FreeNAS on - the motherboard, processor, memory, drives, etc., also how you made the USB and the CD.
Oh, and "the box" isn't a virtual machine on another OS, is it?
I don't know that my questions are going to help but this is a very unusual situation.
Archerxplex
It is an asrock b75m motherboard I dont remember the CPU but it is an i7
It has 8 gigs of ddr3 and a 1tb Toshiba and a 4tb Seagate and a 250gb western digital blue
And I made the CD off of my main computer with poweriso to burn it to the CD and it's on a actual machine not a VM
Archerxplex
Ok I got it to work I found an old Dell keyboard and tried it and it worked. Moral of this all is that freenas does not like booting with corsair keyboards
