Installing/Running MiniDlna
Mjrpainless
I have previously had MiniDLNA working on my old freenas box, but i thought it was time to upgrade my hardware and OS to 9.1.1
I Am fairly new to any advanced freenas use but here what i have done so far.
Several clean installations of 9.1.1
setup a ZFS pool
then went to plugins and installed the MiniDLNA plugin from there.
I waited for it to create the jail and all that jazz.
Now im not to sure where to go from here, its like the service isnt active, as if i open up DLNA on either my blurray, or tv i dont see ANY service there.
Also have noticed that if i got back to the plugins tab all I have there is the MiniDLNA with no options to install any other plugins or even remove the MiniDLNA plug in.
Any information would be great! thanks
D
dlavigne
Guest
Please post a screenshot with your minidlna entry highlighted under Plugins in the tree menu.
d12
Different newb, same issue. Hopefully this isn't a hijack.
I can SSH into the box, SAMBA shares work, but I error out when trying to install included plugins.
Screenshot attached, here are logs: http://pastebin.com/VbKBAJ8g
Any help appreciated, thanks.
d12
Solved. Seems the issue was running FreeNAS-9.1.1-RELEASE-x86.iso i386: 32-bit x86 ISA. Worked fine with FreeNAS-9.1.1-RELEASE-x64.iso x86_64: 64-bit x86 ISA
