I am trying to install Truenas Core and running into difficulty. I am using an older M.2 2242 SATA3 SSD to install the OS onto. I have made two USB boot drives for the installation. When I boot from the USB boot drive I do get install screen. After it counts down from 10 it does something but then I just get a curser in the upper left corner of the screen. The installation does not go to the console setup screen. Do I need to have a storge drive installed to complete the installation?
Also, this SSD that I am trying to use was pulled out of a Chinese tablet that I was using. The SSD is basically new & has not been used. I replaced it with a 256G SSD. It is possible that there is something wrong with the SSD?
Other Components:
Asus Prime B560M
Core I511400
Corsair DDR4 3600 MHz 16G
Other Components:
Asus Prime B560M
Core I511400
