More precisely - before installation: .
Problems begin when I create Installation Media on USB. Prior to version 11.2-U6, I did not encounter anything like this.
So: downloaded the ISO file, checked SHA256 - everything is OK. I start "burning" in Rufus or Win32Imager, everything is fine until the last moment (a message about a successful "burning" is like) - but ends with BSOD. The same on 3 computers (Win 7 / Win 10). Moreover - on Win 7 it is possible to reboot only if you remove the USB flash drive, when plugged in - BSOD again. On Win 10 - it loads with mournful moans and allows you to remove and plug USB flash drive with a lot of complaints again. What can be wrong?
