Hi everyone,
Looking for some help here. Have been using Freenas for a few years and had had a couple of instances of losing data and now find myself in a similar situation again.
Got an error for one of the drives going bad, replaced one of the 4 3TB WD Red drives with a new 4TB WD Red drive. Booted the system and now I am getting an "Error 'i386-pc' not found" and ending up in Grub Rescue.
here is the structure for the HD0,gpt2 and HD0,gpt2 partitions
/grub
/ROOT
/ROOT/default
/ROOT/Initial-Install
/ROOT/9.10.XXXXX
/ROOT/9.11.XXXXXX
have tried to set the root to both the partitions and tried to boot from the directories listed above but with insmod normal get the same error from regular boot.
Is there a way I can recover access to my drives from this situation?
Thank you
/grub
/ROOT
/ROOT/default
/ROOT/9.10.XXXXX
/ROOT/9.11.XXXXXX
Thank you
